loss of power... - JeepForum.com
post #1 of 18 Old 12-17-2007, 04:41 PM Thread Starter
Shinitenshi
loss of power...
Aight when am at a shop and i shift to first gear everything fine but when i get to 2nd / 3rd gear i feel lack of power. Like if am hitting the gas but its not accelerating at all. any clue what i should check?
1997 Jeep Wrangler SE 4x4
Low output 4 Cylinder Jeep Club Member #0492
Shinitenshi is offline
post #2 of 18 Old 12-17-2007, 04:52 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Has your fuel economy taken a corresponding hit? Have you had any Check Engine lights since the problem started?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is online now
post #3 of 18 Old 12-17-2007, 04:55 PM Thread Starter
Shinitenshi
I feel like my fuel runs faster now but haven't checked since i hardly ever fill up my tank >.< student here and never have enough money to fill up. how would i go on and check how much my fuel economy is? and nope no check engine light.
post #4 of 18 Old 12-17-2007, 05:07 PM
Jerry Bransford
Administrator
Without knowing what your fuel economy was before, knowing what it is now won't help as much. But at least we can tell if it's drastically off by checking it on the next full tank.
Go fill up your gas tank, all the way until it can't take any more, and then reset your trip odometer to zero before you leave the gas station.
The next time the tank gets low and you fill up, divide the number of gallons it took to fill up again into the total number of miles you drove on that tank to calculate your mpg. To make the mpg calculation as accurate as possible, put as many miles as possible on the tank before refilling it.
How's your air filter? Is it clogged with dirt, even partially? How many miles (years?) has it been since it was changed?
post #5 of 18 Old 12-17-2007, 05:13 PM Thread Starter
Shinitenshi
I bought this jeep around six months ago and I haven't changed it at all. I don't know if he changed it but when i opened it up 1 month ago it didn't seem that dirty inside. soo... I didn't buy a new one, should i replace it before i check my mpg?
post #6 of 18 Old 12-17-2007, 05:17 PM
Jerry Bransford
Administrator
Whether or not it needs a new air filter is a judgement call. Take it out, bang it flat-side on a table to shake the loose dirt out of it and then see if you can still see much light passing through it when you hold it up to the light. If the light is being blocked by dirt in the filter, you can bet the air is being blocked too.
post #7 of 18 Old 12-17-2007, 05:24 PM Thread Starter
Shinitenshi
Aight man thanx a lot ill fill up my tank and ill let you know how much my fuel economy is. Till then ^^
post #8 of 18 Old 12-26-2007, 06:48 PM Thread Starter
Shinitenshi
Alright Jerry I check how much my mpg was and it turned out to be 15.02
Gallons: 12.877
Miles: 193.5
Feed Back plz ^^
post #9 of 18 Old 12-26-2007, 06:56 PM
Jerry Bransford
Administrator
Gallons: 12.877
Miles: 193.5
Feed Back plz ^^
If my TJ ever got 15.02 mpg again, I'd be grinning from ear-to-ear. I can't remember if it ever got that good of mpg even when it was new, though it might have.
post #10 of 18 Old 12-26-2007, 07:00 PM Thread Starter
Shinitenshi
well everything on my jeep is stock except the tires but there only 30's mud tires. shouldn't i get around 20ish?
post #11 of 18 Old 12-27-2007, 05:26 PM
BlueFlame
BlueFlame's Avatar
What RPM are you shifting into 2nd and 3rd?
You aren't shifting according to that stupid shift reminder light are you? If so, that would definitely explain why you have no power...
Park brake off? (just kidding, well sort of..)
The 4cyl can get as much as 20 mpg, some do some don't.
BlueFlame is offline
post #12 of 18 Old 12-27-2007, 05:40 PM
Jerry Bransford
Administrator
That was a VERY good point that I never think of asking when someone complains of a lack of power.
post #13 of 18 Old 12-27-2007, 05:45 PM
SecondTJ
SecondTJ's Avatar
With my old '97 2.5 5-speed, I used to average around 17mpg. But that was completely stock, including the little 28" tires.
With bigger tires, and being mud terrains, you will lose a few mpg. So getting 15 mpg sounds about right.
Also, because you have bigger than stock tires, you will lose a bit of power.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #14 of 18 Old 12-27-2007, 05:51 PM
KnightFire
KnightFire's Avatar
When dealing with a loss of HP, I always target the main culprits. Fuel, Spark, and Air. Ensure you have adequate fuel pressure, ensure your getting GOOD spark, and make sure your motor is breathing freely.
Fuel and spark are easy to check, that leaves air.
Check the intake and exhaust, ensure the air is flowing freely. It's not uncommon for catylitic converters to fail in higher mileage vehicles. Check your O2s, ensure you don't have a vacuum leak or exhaust leak.
These quick checks will usually turn up the culprit.
Good Luck!
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #15 of 18 Old 12-27-2007, 05:56 PM
Jeepinty
I second Knightfires suggestion on checking the exhaust. It sounds like what happened to my 2nd jeep, the cat was plugged and it drove fine on in town but wouldnt go above 50. An exhaust shop can check the backpressure easily and quickly to tell you if that is the problem.
Jeepinty is offline
Loss of power ImRaptor YJ Wrangler Technical Forum 30 11-12-2006 06:10 PM
Loss of Power AHighFiveToLife YJ Wrangler Technical Forum 2 03-21-2006 10:54 AM
Loss of power??? JimDandy TJ Wrangler Technical Forum 4 05-01-2004 10:14 PM
'95 YJ 4.0 loss of power RedBug YJ Wrangler Technical Forum 21 04-20-2004 08:23 AM
Power Loss ! bigjeep310 YJ Wrangler Technical Forum 12 03-28-2004 03:49 AM
