loose tube under battery tray - JeepForum.com
post #1 of 8 Old 11-16-2007, 05:08 PM Thread Starter
Rocky.ca
on my 97 tj.... there is aloose tube, looks to be a vacuum tube. its pretty short and just ends.... it plugs into a box that is under there. what is it and what should it be hooked up to?
Thanks,
Mike
Black 97 TJ SE 4bangin' away.
3" BDS lift
33" A/Ts
Sound System
custom de-milk jugged bumper :D
Rocky.ca is offline
post #2 of 8 Old 11-16-2007, 05:55 PM
BlueFlame
BlueFlame's Avatar
should be plugged into a little black box under there.
Look around, you should find a vacuum line it plugs into nearby.
The box is the vacuum accumulator.
I bet your heater ssytem doesnt switch from defrost to floor to vent....
BlueFlame is offline
post #3 of 8 Old 11-16-2007, 06:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If that tube is rubber and protruding out of the firewall under the battery box, it's the drain tube for water (condensation) that comes out of the a/c system.
Jerry Bransford is online now
post #4 of 8 Old 11-16-2007, 08:34 PM
BlueFlame
BlueFlame's Avatar
Good point, but that's about 1/2" on mine, doesnt' resemble a vac line much.
post #5 of 8 Old 11-16-2007, 08:40 PM Thread Starter
Rocky.ca
nono. this little black tube (maybe 1/8" OD) it plugs into the little black box but the other end doesnt have anything to plug into. and oddly enough i can switch between all of the heater settings. but i do have a vacuum leak because when i accelerate hard i dont have the ability to switch it anymore:P I FOUND THE LEAK. but how to fix it?
3" BDS lift
33" A/Ts
Sound System
Rocky.ca is offline
post #6 of 8 Old 11-17-2007, 07:51 PM Thread Starter
Rocky.ca
anyone??????
3" BDS lift
33" A/Ts
Sound System
Rocky.ca is offline
post #7 of 8 Old 11-17-2007, 08:26 PM
Jerry Bransford
Administrator
You're gonna have to provide more information and/or photos of what you're talking about. I am still in the dark on what/where is broken/leaking/what the leak is that you found.
post #8 of 8 Old 11-18-2007, 03:40 PM
BlueFlame
BlueFlame's Avatar
Has to be there. The little plastic box under the battery is the vacuum accumulator, and it connects to the vaccuum lines that come through the dash right by the battery, spit and go to the accumulator and across the firewall to the engine and cruise etc (on mine.) If your heat/defrost works at all, you have vacuum from the engine, so the line is around there somewhere.
Here's a pic but your 97 4cyl will not look like my 03 6cyl, but the vac line from the dash is in the yellow circle, it comes through that foam gasket, splits and goes under the battery and over to the engine and cruise.
second battery tray wtf? epeck87 TJ Wrangler Technical Forum 14 06-23-2009 08:04 PM
2nd battery tray BiGEN JK Wrangler Technical Forum 11 10-27-2008 06:52 PM
Need Help : Battery Tray TheJackel TJ Wrangler Technical Forum 11 04-17-2008 11:01 AM
Adding 2nd Battery anyone using LH tray? bonofied suiter TJ Wrangler Technical Forum 6 02-06-2008 11:46 PM
Tube Fender w/Tomken Dual Battery Tray harpo1 TJ Wrangler Technical Forum 14 06-25-2007 02:29 PM
