Loose Switch in Ignition Cylinder (Power for Radio) - JeepForum.com
post #1 of 2 Old 04-11-2004, 11:41 AM Thread Starter
czar97
Anyone ever had problems with the ignition cylinder (key cylinder in steering column). As far as starting the jeep everything works great. But when you wiggle the key around, the power to the radio goes on and off. Itís as if something is loose in the key ignition cylinder. Anyone have this issue before.
-Matt
2003 TJ Sport
4L, 5 spd. manual
3.73 gears four wheel disc
32 x 11.50 Cooper Discoverer STT
2" RE Budget Boost, Spidertrax Wheel Spacers
czar97 is offline
post #2 of 2 Old 07-24-2004, 09:33 PM
44 NSB
NSB Florida Jeep
44 NSB's Avatar
-Matt
I'm having the same problem with my 97 TJ. What did you do replace the cylinder? Not only does it cause the radio to cut out it also renders the windshield wiper inoperative.
44 NSB is offline
HUGE problem with '87 4.2L - Ignition Switch Power Issues (No power on key turn) jesseleikerjeep YJ Wrangler Technical Forum 11 02-26-2016 05:25 PM
Ignition switch or something else? Key on + no power Diabl0 TJ Wrangler Technical Forum 64 03-13-2012 06:56 PM
No power to my ignition switch ImpactFabWorks YJ Wrangler Technical Forum 9 04-01-2009 12:30 PM
have no power to my ignition or radio Nick88YJ YJ Wrangler Technical Forum 1 12-11-2008 10:30 PM
Turn signals, wipers, and radio shut off. Bad ignition switch? wood714 TJ Wrangler Technical Forum 2 10-01-2008 08:51 PM
