Loose Drag Link? - JeepForum.com
post #1 of 4 Old 04-22-2010, 09:30 AM Thread Starter
MrsVanWhowho
Loose Drag Link?
Any idea what would cause the drag link to become loose when the bolts are still tight? If you grab the drag link like your grabbing a bar with both hands it will rotate forward and back - like your cranking the gas on a motorcycle.
1999 WJ - Build in Progress - SOLD
2001 XJ - "Steel Blue"
2009 Challenger SRT 8 - Fun Car
MrsVanWhowho is offline
post #2 of 4 Old 04-22-2010, 10:54 AM
boardsurfer
2014 JK Wrangler
That is normal.
boardsurfer is offline
post #3 of 4 Old 04-22-2010, 01:38 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by boardsurfer View Post
That is normal.
Yes and no.
Due to the tie rod ends, you should be able to rotate the bar by hand, but it should take substantial effort and not want to turn very far. If it turns very easily, and/or rotates very far easily, the tre's are getting worn.
On most vehicles that's no big deal, but on a TJ it can make a big difference.
BlueFlame is offline
post #4 of 4 Old 04-22-2010, 04:20 PM Thread Starter
MrsVanWhowho
Originally Posted by BlueFlame View Post
Yes and no.
It turns a lot and very easily.
The TJ is making a clunking noise during acceleration and deceleration. That's the only thing that is loose under there that may be linked to the clunking noise.
Also, if I had the money, I would buy your Jeep in a second. You have done a great job with it. Very well put together.
Loose drag link / pitman arm - loose steering oren77 TJ Wrangler Technical Forum 15 01-30-2012 02:48 PM
Drag link end scouperacer1994 TJ Wrangler Technical Forum 3 04-15-2007 07:29 PM
Drag link hits Swaybar link.... 5150 TJ Wrangler Technical Forum 12 07-21-2005 12:10 PM
***HELP Can't get my SS Pin out of drag link*** BlueJ TJ Wrangler Technical Forum 11 02-25-2005 09:45 PM
V8 ZJ tie rod & drag link will it fit in a YJ?? Scubajeep YJ Wrangler Technical Forum 2 10-06-2003 03:29 PM
