Looking for springs that will yield 3.5" of lift - JeepForum.com
post #1 of 22 Old 09-24-2008, 12:12 AM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
I'll be more detailed. I am running stock rubi springs & BB spacers. I have about 3.5" of suspension lift right now with a 1" BL & I like it. But the ride is pretty stiff, even with skyjacker hydros. I'd like to ditch the BB, find springs that will give me 3.5" of suspension lift & help soften the ride at the same time. for the record, the ride was stiff even before I added the BL.
***EDIT**
after further review, I realized that I have closer to 3.25" of lift. So springs that will yield 3.25" with my 4 banger are now in the running.
The problem I have been running into is even though a set of springs is advertised as 3.5" lift, they usually yield much more than that, especially with a 4 banger like I have.
I looked into RE 3.5" springs, but was told that with my Jeep, the RE 3.5" springs will yield closer to 4.5" and I don't want that much supension lift because I don't want to spend $$ on a SYE and CV drive shaft right now. I emailed an OME retailer about springs, but got no reply.
I have also considered ditching my 1" BL and just getting a 4" lift kit, but I don't want to spend $$ on a SYE and CV drive shaft right now. I don't need a T-case drop with my current setup, but I suppose if I did a 4" lift and T-case drop, the skid would be at the same height as it is now, right? anyway, again, would the springs yield a true 4" of lift, or would it be more? I'd be concerned if the springs yielded more than 4" my driveline would be too far out of whack with just the MML & T-case drop... and I dont want to chance that. Plus, I don't want to end up with a kit that has springs that are too stiff for my Jeep.
So basically I have the same issues with either scenario. But one thing I know is a 3.25" suspension lift (*please note edit to 3.25") with 1" BL is working for me & usually it's good to go with what you know.
thanks in advance for any advice and by all means, vendors feel free to chime in.
"The best advice I can give you is never listen to my advice"
+GRAVES+ is offline
post #2 of 22 Old 09-24-2008, 07:20 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
My Rancho 3" HD springs give exactly 4" of lift and haven't sagged after 18 months.
TheBoogieman is offline
post #3 of 22 Old 09-24-2008, 09:40 AM
never monday
having Rubi springs on a 4 banger is part of the problem. The spring rate is too stiff. try finding a set of 4 banger springs. Or look at the Rancho 2.5" spring for the 4.0
never monday is offline
post #4 of 22 Old 09-24-2008, 01:09 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
haha- oh yes, my dentist & I are quite aware of that!
The rubi springs are the same height as the stock 4 bangers, but stiffer. Thats why I get an extra 1" + of lift from them. I dont want to go back to stock 4 banger springs because I like the extra height.
will the rancho 2.5" coils yield 3.5" of suspension lift with my 4 banger Jeep without sagging over time? and how do they ride? I am guessing better than stock if you are recommending them.
many people, including mechanics, have told me "coils only effect height, not the ride quality". but that sure isn't true in my experience.
thanks
+GRAVES+ is offline
post #5 of 22 Old 09-24-2008, 01:32 PM
never monday
I'm not sure what the coils will give on a 2.5 I've only used them on 4.0's. Coils effect ride height and ride quality. You've discovered this with the Rubi springs. The higher the spring rate the stiffer the ride.
post #6 of 22 Old 09-24-2008, 01:43 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
exactamundo. and this brings me back to my original delimma. i want 3.5" of lift with good ride quality, but I am having a hard time finding springs that will yield 3.5" with my 4 banger. The guy that posted before you has a 4.0 & said he said 3" rancho springs yieled 4" of lift with his Jeep. Who knows what they'd do to my Jeep.
Maybe some vendors can chime in? I can't be the first person that has asked this question.
thanks
+GRAVES+ is offline
post #7 of 22 Old 09-24-2008, 01:53 PM
Zennashton
So you wont a soft 3.5 inch lift for your 4 banger? Thats a hard combo to come up with. Maybe some med duty ome 2.5 springs would do it. But I can only guess. Call an talk to Dirk at http://www.dpgoffroad.com/TJ_LJ_OME_Kits.htm
Zennashton is offline
post #8 of 22 Old 09-24-2008, 01:54 PM
girly04LJ
2011 JK Wrangler
The best ride I have ever had was a 3" teraflex kit with teraflex shocks and I would bet with a 4 cylinder you would get between 3.5 and 4 inches of lift
girly04LJ is offline
post #9 of 22 Old 09-24-2008, 02:02 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
Does teraflex post here? if so, can you chime in please?
soft "er" ride. I emailed & called these guys http://www.oldmanemu.com , but they never replied & didn't pick up the phone. I'll try your buddy Dirk when I get a chance.
thanks
+GRAVES+ is offline
post #10 of 22 Old 09-24-2008, 02:27 PM
TeraFlex
Sure!
3" springs sit just a hair over 3" (like 3.25") on a 6 cylinder TJ, so on your 4cyl you're probably going to see pretty close to the 3.5" you want.
Whatever springs you choose, make sure you get a good set of shocks that are valved for your vehicle--that's almost certainly a huge part of your ride quality issues. Most "budget" shocks like yours are just generically valved for anything, meaning they'll fit on anything from a lightweight Jeep or a heavy one-ton truck. That truck (for example) will need a much stiffer shock to function than your Jeep, so your result is a jarring ride.
TeraFlex is offline
post #11 of 22 Old 09-24-2008, 02:29 PM
TheBoogieman
Disturbed
thanks
That was me and it won't effect yours more than that.The rubi springs give 1/2" on a 4.0 and not much more on a 2.5.My brother has them on his and it didn't lift it at all.I'd go with Rancho 2.5"HD springs(or RC 2.5 springs and add a spacer if needed) for 3.5" lift.
post #12 of 22 Old 09-24-2008, 02:37 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
My stock springs had 70,000 miles when I replaced them with rubi springs that had 300 miles on them. this gave me 1" lift in the front & 1.5" lift in the rear. the rubi springs are 129AB & 105AA
However I just re- did my math and I actually have closer to 3.25", not 3.5" total lift with the spacers. So I'd be happy with springs that give me around 3.25" of lift & a nice ride
I'd prefer to completely do away with spacers if possible.
I'd really like to hear from some vendors
thanks
+GRAVES+ is offline
post #13 of 22 Old 09-24-2008, 02:46 PM
Kpat
I got 3.5" of lift from using the springs from a v8 grand cherokee in the front and almost 4" for the rears from a ford crown victoria(police edition.
Cost 100 dollars for springs from scrap yard plus 15 from a spacer i made for the front on a lathe.
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan!
Kpat is offline
post #14 of 22 Old 09-24-2008, 02:49 PM
Kpat
Oh the only thing i forgot to mention is that it is a lil on the rough side but i expected this. Running 4" lift on Short CA will be rough but the springs are fairly thick which doesn't help either.
Kpat is offline
post #15 of 22 Old 09-24-2008, 03:06 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
you completely missed the point of my post
+GRAVES+ is offline
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
Anyone Running OME 2.5" heavy duty lift springs od BDS 2.5" springs 1992 renagade YJ Wrangler Technical Forum 6 03-31-2009 07:12 AM
Mixing 4" lift components with 2" springs? GreenJip TJ Wrangler Technical Forum 11 06-25-2008 07:19 PM
What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift Dwayne93YJ YJ Wrangler Technical Forum 3 06-02-2008 11:15 PM
how much lift does the re3.5 really yield? alex71 TJ Wrangler Technical Forum 8 04-07-2006 08:58 PM
