Looking for a smoother ride.... - JeepForum.com
post #1 of 7 Old 12-30-2006, 08:21 AM Thread Starter
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
I have a 4inch Rough Country lift. Good cheap lift. When the tax refund gets here, I'm looking to soften the firm ride this lift has. Should I be shopping for different 4inch springs, or would different shocks make the changes I'm wanting.
Suggestion appreciated.
Thanks.
1948 CJ2a
Airborne4X4 is offline
post #2 of 7 Old 12-30-2006, 08:24 AM
deadman
Rough Country lives up to it's name....rough. Try a different company's spring. I have a Rough Country setup in my pickup and it is the roughest ride I've ever had. I don't know which company to suggest though.
deadman is offline
post #3 of 7 Old 12-30-2006, 08:26 AM
Trombino
Trombino's Avatar
1978 CJ7
Check out the Old Man Emu (OME) shocks. I hear they provide for a great ride.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #4 of 7 Old 12-30-2006, 08:33 AM
2fastlx
2fastlx's Avatar
Thanks.
what shocks do you have? I got the pro comp shocks and they make the ride rougher than you can belive.
Colorado Jeep Club Member #44
I couldn't really understand what you were saying or asking, but I think you need a bigger hammer.
2fastlx is offline
post #5 of 7 Old 12-30-2006, 08:40 AM
Hitmanx800
OME Springsa and shocks is my recommendation, they do make 4inch springs
1998 Wrangler Sport
OME 2.5HD
JKS Front/Rear Adj. Trackbars
Home Made Disconnects
D30/D44 3.73 Trac-lok
Cragar Black Soft 8's & 32x11.5 BFG MT
Hitmanx800 is offline
post #6 of 7 Old 12-30-2006, 09:05 AM Thread Starter
Airborne4X4
1948 CJ2A
I got the shocks that came with the kit. Makes them RCs, I guess. Seemed awlful stiff when I was installing them.
1948 CJ2a
post #7 of 7 Old 12-30-2006, 09:31 AM
Tumble
I also have the RC 4" X-Series lift. Same problem with the rough ride. I just swapped out my shocks to OME LT's. It now rides MUCH better. I would try the new shocks first then replace the springs if you still want a softer ride.
OME's
Tumble is offline
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 11:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 08:27 AM
Need Smoother Ride GA TJ TJ Wrangler Technical Forum 16 11-09-2006 03:47 AM
need a smoother ride rogasm TJ Wrangler Technical Forum 11 08-21-2004 07:08 PM
Shocks for a smoother ride aboynamedmoose YJ Wrangler Technical Forum 12 10-13-2002 12:46 PM
