Looking for a skid plate - JeepForum.com
 1Likes
post #1 of 30 Old 09-17-2017, 03:19 PM Thread Starter
Tylervalo
Like the title says, I'm looking for a skid plate to replace the stock shovel. My Jeep is an 06' 4.0, 6 speed. It has a 1.25" BL and 1" MML, ZJ springs up front to level it and sitting on 31" MT's. I'm basically looking for something to tuck up a bit tighter since I don't plan on lifting anymore. At most I would do some 1" spring spacers but I want to stay on 31" tires.
Pic for reference:
Tylervalo is offline
post #2 of 30 Old 09-17-2017, 10:16 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have an idea on how much you want to spend?...
Knuckelhead is offline
post #3 of 30 Old 09-18-2017, 05:45 AM
NotURMailman
NotURMailman's Avatar
As mentioned above, your budget will have a big effect on your options here.
I would recommend the Savvy Underarmor, but you will need a SYE and CV rear driveshaft to go with it. Even with your low/no lift and MML raising your t-case that much will put your rear driveshaft at extreme angles. When you do that it will lead to a need for adjustable rear control arms. And then you will likely need an angled rear track bar bracket. And that may or may not cause a need for lower end rear shock brackets or coil bucket trimming...
It's a snowball effect and not a simple mod. In my opinion it's worth it, but you need to be aware how involved it is.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #4 of 30 Old 09-18-2017, 06:43 AM
EricD
I have been looking at the TNTCustoms skid, but have not decided yet.
EricD is offline
post #5 of 30 Old 09-18-2017, 07:46 AM Thread Starter
Tylervalo
I'm not opposed to doing an SYE, I've already picked up a good condition driveshaft from an Explorer to get cut when I go that route. Preferably I would like skid that I could use now as it sits, then go SYE if I do a 2" lift down the road. I don't do a lot of off road and I stay away from rocks, just need the extra clearance when I'm in ruts created by 33's and 35's.
post #6 of 30 Old 09-18-2017, 07:50 AM
NotURMailman
Any flat or close to flat belly skid is going to need a SYE and CV shaft and then adjustable arms to adjust the pinion angle. Adjusting the pinion angle may or may not lead to the requirement for a track bar bracket and something needing to be done about the shock mounts.
The increase in clearance is going to be particularly helpful at lower heights.
post #7 of 30 Old 09-18-2017, 07:52 AM
Ironhead
check out undercover fabs, they have several different skid heights, from replacing stock to raising it ~3.5". they also offer their skids in aluminum
Ironhead is offline
post #8 of 30 Old 09-18-2017, 08:25 AM
offroadman83
Go with next venture motorsports...my ucf skid is disappointing to say the least
offroadman83 is offline
post #9 of 30 Old 09-18-2017, 08:37 AM
NotURMailman
I've had two friends install UCF skids and they both said it should stand for "U Can Fab" because nothing fit quite right...
post #10 of 30 Old 09-18-2017, 09:19 AM
Jeepsr4me
your diffs are going to hang up way before the skid.... I am a fan of the camel trophy series and they run tiny tires compared to the ruts.. And the diffs drag more than any skid plate..
I uderstand you want to get that mud scoop up some. I just dont see how it hangs down lower than your diffs..
Could get something like this to keep from allowing the skid to dig in. Way lesss work than a tummy tuck..
Jeepsr4me is offline
post #11 of 30 Old 09-18-2017, 04:59 PM
JEK3
JEK3's Avatar
I'll agree with this statement.
JEK3 is offline
post #12 of 30 Old 09-18-2017, 05:10 PM
b00mb00m
I also confirm, took me about an hour to slot 3 holes with a dremel tool about 1/2" each. Factory plate lined up fine UCF no so much.
b00mb00m is offline
post #13 of 30 Old 09-18-2017, 05:44 PM
biffgnar
biffgnar's Avatar
Never run their stuff myself, but did spend some time helping a friend make it work consistent with this.
biffgnar is online now
post #14 of 30 Old 09-18-2017, 07:05 PM
JEK3
JEK3's Avatar
IIRC, the way the holes lie, they basically shortened the factory skid, without accounting for the fact that the drivetrain actually pivots around the motor mounts instead of just lifting straight up.
I ended up drilling a new set of frame mount holes about 1.5" off from the original ones. I still don't like the way it sits. I'm eventually going to put in a tranny mount crossmember.
JEK3 is offline
post #15 of 30 Old 09-18-2017, 07:24 PM
Pine_Cat
Pine_Cat's Avatar
The Clayton belly skid is streamlined, lifts your transfer case 1.25" so you would not need a SYE
2017 JK Sahara (my Smart car)
2011 KK Liberty (H&R lift springs, OldManEmu shocks/struts, skinny 32s)
2009 Kia Sorento (H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, skinny 31s)
2006 TJ budget LCG prerunner (see profile)
2006 Chevy Trailblazer (SWB-EXT lift, rear LJ Nth 4.5" springs, skinny 32s)
1998 Dodge Durango (SuspensionMaxx and Roadmaster lifts, rear Truetrac, skinny 32s)
Pine_Cat is offline
