Looking for a rear bumper/carrier - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Looking for a rear bumper/carrier
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 04-06-2007, 04:06 PM   #1
unsung
unsung's Avatar
I'm trying to decide between two...
Jeeperman's which is on sale for $725 shipped, or the LOD Extreme which goes for around $500 shipped.
I really like the 3rd brake light inside the wheel option of the Jeeperman.
Thoughts?
unsung is offline   Reply With Quote
Unread 04-06-2007, 04:17 PM   #2
Pipedrummer
I just installed the LOD xtreme duty 2 days ago....fairly simple to install and it's awesome! i drove 100 miles today and it was fine. There is a lot of clearance, so i can actually see out the back window. Very quiet except for the d-rings rattling a bit, but thats expected. I opted not to put a third brake light in...even tho its technically illegal, i don't see the need for it. Altho something could def be rigged up like a tuna can or even getting a center cap and putting a red light into it. I've also seen people use the top of teh A-frame for a brake light.
bottom line is that the bumper rocks, and def worth the steal at 500 bucks.
I will be getting a jeeperman front, but the rear is just too expensive IMO.
Good Luck
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top
Pipedrummer is offline   Reply With Quote
Unread 04-06-2007, 04:20 PM   #3
PackMan
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
I have the Jeeperman rear and it is one sturdy SOB. The hinge uses axle bearings. It comes with the frame tie-in kit, I've got 14 grade 8 bolts holding that thing to the frame and x-member. I've hung my high-lift jack from it, and will move my CB antenna to it after my lift. It is a "slam shut" variety, and you don't have to worry about pins and the like. It does not rattle at all. I got the version with rear corner guards, too... a little something under the corners to prevent carnage.
The only con is to inspect the powder coating when it arrives. Mine is in great shape, a couple of people have reported problems.
PackMan is offline   Reply With Quote
Unread 04-06-2007, 05:35 PM   #4
Axkick
A.K.A Ron
Axkick's Avatar
They both look the same and seem to be built the same...I just ordered my LOD xtreme....
Saved a couple hundred...I can use that for something else....
HEY pipedrummer.....how long did it take you to install...and did you have to drill? was it a pain....
Axkick is offline   Reply With Quote
Unread 04-06-2007, 05:53 PM   #5
Shorty
Inform me. What is the LOD extreme? I'm buying one in a week or so. I'm looking to spend around 400.
Who lives in a pineapple under the sea?
"Horrendously scratched black jeep club member #7"
(w/ Hurculined accents)
Shorty is offline   Reply With Quote
Unread 04-06-2007, 06:15 PM   #6
Axkick
A.K.A Ron
Axkick's Avatar
You can check it out here.....
http://www.4x4xplor.com/LoD-Xtreme.html
Unread 04-06-2007, 06:57 PM   #7
jpark
May want to check out llamabumpers as well. I'm going with their rear bumper with carrier towards the end of this summer.
http://www.llamabumpers.com
jpark is offline   Reply With Quote
Unread 04-06-2007, 07:00 PM   #8
4xfiend
Thoughts?
I have a light on the inside of the wheel on my LoD xtreme. I only had to drill two holes to make it work. Really easy. I got the light from Rock Hard.
Sorry about the pic quality. My photography skills aren't the best.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | LoD xtreme duty rear bumper/tire carrier | Rokmen Mercenary rockers |
Originally Posted by Jerry Bransford
I DON'T FRIGGIN' CARE!!!
Originally Posted by Jim M
Please keep the facts to yourself; nobody here wants to hear them. This was a perfectly good internet argument until you came along with anecdotal evidence.
4xfiend is offline   Reply With Quote
Unread 04-06-2007, 07:19 PM   #9
Pipedrummer
took like 45 mins.... you need to drill 4 1/2" holes into the crossmember....wasn't too hard, just start w/ a smaller bit and work your way up. sharpen a pencil as far down as you can, thats about the only thing i could get in there to mark the holes... I bought a 1/2" dewalt bit at lowe's w/ a 3/8 shank b/c i dun have a 1/2" drill.... $18 ouchh
the hardest part was threading the bolts thru those holes into the plates behind the crossmember....the driver's side was esp hard to line it all up.
i used the 4x4xplor write-up, helpful altho you can temp. attach the bumper to the bottom 2 bolts to hold it up while you mark the holes, you don't necessarilly need another person to hold all the weight (just make sure the bumper's flush to the crossmember when you amrk the holes).
4xfiend, i like the brake light...maybe i will make mine legal now
Unread 04-07-2007, 12:38 AM   #10
GGALJOUR
I installed a LOD heavy duty bumper and marked the holes pretty easily by putting some masking tape on the end of the bolts, and then coating the masking tape with some blue chalk that could be used to mark lines when cutting lumber. Held the bumper in place, pushed the chalky end of the bolt into each hole, and when I removed it I had perfectly lined up marks to drill my holes.
Also for the bit - try looking for a kit with a 1/2" drill bit. Home Depot had no 1/2" bits for less than about $16. I went to Walmart and got a whole new set of Black and Decker drill bits, including the 1/2" for about $9.
Good luck - take your time. I'm real happy with my LoD so far. Will be looking to them for a front bumper soon.
99 Sport - White w/ Dark Tan
REBB 32" BFG M/Ts on Black RockCrawlers
4.0L 5spd K&N Filter LoD Heavy Duty Rear Bumper & Tire Carrier
GGALJOUR is offline   Reply With Quote
Unread 04-07-2007, 07:31 AM   #11
Shorty
Anybody have any experience with the Hanson A-Frame rear bumper/tire carrier. It's a damn good price.
Unread 04-07-2007, 08:02 AM   #12
jpark
That's just for the carrier and not the bumper at least the one I saw on 4wd.com is like that. Check out the llamabumpers link I posted earlier. Similar price to the hanson but includes the bumper.
