Looking into a CAI/Hummer Intake - JeepForum.com
post #1 of 7 Old 11-24-2009, 02:09 PM Thread Starter
KevinR
1983 CJ7
Hey guys,
I'm looking into doing a cowl CAI or maybe a Hummer snorkel for my jeep. My question is- what diameter PVC should I use? Is 2 in big enough, that looks to be about the size of the tube coming out of the stock filter box (which I'm going to try to retain.) Also, have any of you guys with a hummer snorkel had issues with water washing over the hood (ie hitting a puddle) and hydrolocking the engine? Thanks guys!
Kevin
KevinR is offline
post #2 of 7 Old 11-24-2009, 02:11 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
did you look at the several DIY Hummer/Snorkel write-ups linked in the CAI FAQ?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 7 Old 11-24-2009, 02:18 PM Thread Starter
KevinR
1983 CJ7
Yes, I was trying to get a feel for dimensions. I hadn't seen any listed (maybe I looked at the wrong ones haha) And I was also looking for some more information on the issue of hydrolocking because I had read briefly about it in one thread but it wasn't elaborated on more than that. Maybe using a prefilter could help that?
KevinR is offline
post #4 of 7 Old 11-24-2009, 02:21 PM
patricknolan
Watch videos of jeeps on youtube going through puddles. That should give you a good approximation on how high you need your filter to be to be able to go through a puddle X feet deep.
patricknolan is offline
post #5 of 7 Old 11-24-2009, 02:40 PM
Benderff
Benderff's Avatar
I am also getting ready to do one. The write-ups I read used 2-1/2" or 3" pipe. One of them picked up an extra air box to intake pipe and used that. There are a number of write-ups about this. If you are having a hard time finding them on here try Google.
Benderff is offline
post #6 of 7 Old 11-24-2009, 03:07 PM Thread Starter
KevinR
1983 CJ7
Thanks Benderff, that's what I needed I'll start designing around a 2.5 inch pipe and see what I can make work
KevinR is offline
post #7 of 7 Old 11-24-2009, 04:19 PM
Benderff
Benderff's Avatar
You can search Cowl intakes as well for more under the hood ideas. This is what I'm thinking about doing.
Jeep Horizons :: 4.0L Cold Air Cowl Intake With a snorkel cap.
If you use a precleaner keep in mind how much air flow you will need it to allow.
C.I.D.-Cubic Inch Displacement R.P.M.-Revolutions Per Minute Vol.Eff.-Volume Efficiency
Gasolineup to 2500 r.p.m.=.80 2500 to 3000 r.p.m.=.75 3000 to 4000 r.p.m.=.70
Benderff is offline
Hummer intake for YJ-- write-up with many pics swedishdwarf YJ Wrangler Technical Forum 36 05-23-2013 05:51 PM
need help finding a hummer intake cap legend6009 Wrangler General Discussion 5 05-02-2012 07:55 PM
hummer cold air intake on a YJ? muddy93 YJ Wrangler Technical Forum 4 05-12-2011 09:19 PM
a different hummer intake question... yellowismellow TJ Wrangler Technical Forum 6 02-24-2007 08:52 AM
hummer intake yellowismellow TJ Wrangler Technical Forum 4 11-07-2006 08:30 PM
