Looking for help Code P0303 - JeepForum.com
post #1 of 17 Old 06-20-2011, 03:28 PM Thread Starter
drl650
2017 JK Wrangler
I get this code P0303(M) CYLINDER #3 MISFIRE Misfire detected in cylinder #3
2004 Rubicon with 51000 miles.Any one here have this problem? Thanks.
drl650 is offline
post #2 of 17 Old 06-20-2011, 04:32 PM
dflesher65
I posted about 2 weeks ago with the exact same code...I bought some new plugs and reset the computer and now everything is back to normal. Any chance you still have the factory warrenty?
dflesher65 is offline
post #3 of 17 Old 06-20-2011, 06:13 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
7 Years later?
GOLENJEEPTJ is offline
post #4 of 17 Old 06-20-2011, 06:15 PM
GOLENJEEPTJ
When was your last tuneup? Is probably a plug issue or injector issue.
post #5 of 17 Old 06-20-2011, 06:20 PM
etterdog
If you have coil packs you could pull the #3 coil pack and try switching it with another like #1 and if it brings up a code for #1 the it would be the coil pack. might help narrow it down more for you.
etterdog is offline
post #6 of 17 Old 06-20-2011, 06:58 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you ever looked at the 2000-2006 4.0L coil on rail setup?...
Knuckelhead is offline
post #7 of 17 Old 06-20-2011, 07:27 PM
etterdog
Sorry that's right they're an all in one setup. I haven't worked on them allot. Just trying to help
etterdog is offline
post #8 of 17 Old 06-21-2011, 08:32 AM
longbluerubi
I have an 05 LJ and had a P0303. Did some research, one thing I found you may want to check out due to hot weather now is a TSB about rough idle and P0303 after a 10-20 minute drive in 90+ temps. The TSB info is here: http://www.jeepforum.com/forum/f11/p...isfire-394071/. Pulled the plug, didn't see any issues, I cleared the code and put a piece of plastic tube over the injector (didn't buy the kit) and haven't had problems since, been a while now. Not sure if this is what fixed the problem but it hasn't shown backup again. Just something else to consider.
'05 LJ Unlimited Rubicon
I6 4.0L manual 6-speed
OME 2.5" lift+Nitrocharger Sport shocks
1" BL, JKS adj front & rear trackbars, JKS discos
33" BFG A/T
longbluerubi is offline
post #9 of 17 Old 06-21-2011, 08:38 AM
Ross
I had the p303 issue and hot hard start for years, I changed plugs, cleaned the tps, and nothing helped and then I did TSB mentioned above.
I took it to the dealer. I called them to do a little research and they said it only takes a coupled of minutes. They said they would do it for 35 bucks so I let them.
Parts are about 5 bucks and it seems easy. The only question I had was how do you know if you set the injector back in correctly.
My jeep isn't a daily driver and I haven't really had it out and about much so not sure if it actually fixed the problem.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #10 of 17 Old 06-21-2011, 09:50 AM
Knuckelhead
AFSOC Retired
You don't remove the injector when performing this TSB...
post #11 of 17 Old 06-21-2011, 10:19 AM
longbluerubi
I didn't remove the injector. I read the instructions on the TSB and it basically gave you something two wrap around where the injector goes in, so I just slipped a small piece of the black, split ribbed electrical conduit on it, figured that would deflect enough of the heat away. Haven't had the problem since, so thinking that may have done it (I have a 17 minute drive to/from work so I'm frequently in that 10-20 minute heat soak time).
33" BFG A/T
post #12 of 17 Old 06-21-2011, 11:38 AM
Ross
Well ****!
__________________________________________________ ___________________________________
Parts required:
56028371AA Ignition Wire Shield
Repair procedure:
1. Cut insulator sleeve, p/n 56028371AA, to make two (2) insulator sleeves about 25-30 mm (1 in.) in length. See diagram.
2. Install one sleeve around injector #3, with the slit on the upward facing side of the injector. Install the other sleeve with the slit on the downward facing side of the injector.
3. Confirm sleeve is flush to intake manifold surface around injector.
4. Check injector #3 wire and ensure that the injector is rotated to a 2 o'clock position.
TSB for the cold start rough idle and P0303 code: TSB 18-010-01
I say that and just thought I had to remove the injector.
Ross is offline
post #13 of 17 Old 06-21-2011, 12:24 PM
FJ40convert7
I have an 04 Rubicon that just gave me that code on friday. Changed the plugs and have not had an issue YET. Cheap fix so far!
FJ40convert7 is offline
post #14 of 17 Old 06-21-2011, 12:30 PM
Ross
If it is the same issue you will know. If the motor is hot, it is a hot day, and you jeep is harder to start and then runs like crap for about 30 seconds you will probably benefit from this TSB.
Ross is offline
post #15 of 17 Old 06-21-2011, 01:17 PM
Knuckelhead
AFSOC Retired
It worked for my 2000 Sport...
P0303, and nothing else TheHeretic TJ Wrangler Technical Forum 12 12-09-2010 06:21 PM
Code P0303 mcastro70 TJ Wrangler Technical Forum 5 09-04-2010 09:32 AM
Overheat then P0303 code aerojeeptj TJ Wrangler Technical Forum 1 08-22-2010 12:24 AM
loud engine tap and code p0303 mytj TJ Wrangler Technical Forum 3 01-14-2010 11:47 PM
Check Engine Light on...P0303 is the code udrainville TJ Wrangler Technical Forum 6 08-03-2007 07:11 PM
