Looking for a definitive answer - hp 30 - Page 2 - JeepForum.com
post #16 of 20 Old 08-07-2010, 01:27 AM
Jeepster83
Originally Posted by Knuckelhead View Post
When I installed my HPd30 5 years ago i had adjustable lowers (TF) and OEM uppers with a 4" lift, I changed to Currie lowers later on. That was 4 years ago and it's still working well:
LP front axle drive shafts don't do well with this:
Oh yeah, that's a TW DS...
i think what this means is because of the relationship between caster and pinion angle, and also because its worked for others with any combination of upper and lower control arms, that you angles need to simply be within a certain range and there really may not be a "perfect" angle for either. just within a range of difference in degrees.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #17 of 20 Old 08-07-2010, 12:27 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I'm running 4.5 degree caster...
Knuckelhead is offline
post #18 of 20 Old 08-07-2010, 12:34 PM
Jeepster83
im probably going to look pretty stupid, but i dont know what my pinion or caster angles are off the top of my head. can you clarify whether you adjusted either of them and why?
post #19 of 20 Old 08-07-2010, 12:43 PM
Apex
Recon death squad
Apex's Avatar
If your caster angle is too little or too much your Jeep will track terribly and for some reason my steering feels very sloppy. Once caster is adjusted properly the Jeep SHOULD track and handle as well as it did stock (unless you have issues somewhere else)
Pinion angle is set to get rid of driveline vibes caused from too severe of driveshaft angles.
Apex is offline
post #20 of 20 Old 08-07-2010, 01:36 PM
Knuckelhead
AFSOC Retired
With the belly-up TC skid, 4" lift, HPd30 and 35" tires my pinion angle is within 1 degree of being straight with the DS. I then checked my caster angle and it was at 4.5 degree's which is proper for my setup...HTH
hp30 , d30 , dana 30 , uca , upper , control arm , tj , wrangler
I searched but, want a definitive answer (raising seat height) OldGriff TJ Wrangler Technical Forum 48 11-28-2015 02:47 PM
Noob question about tube fenders (searched but didn't find a definitive answer) GomerPyle585 TJ Wrangler Technical Forum 17 03-24-2010 07:23 PM
Definitive language on Warranty sromain JK Wrangler Technical Forum 4 06-29-2008 03:06 PM
can't find a definitive answer to this question?? blacktjsport TJ Wrangler Technical Forum 4 12-14-2005 11:51 AM
need definitive answer on backspacing derby TJ Wrangler Technical Forum 3 11-20-2002 03:17 PM
