Looking to change to a 5 speed. - JeepForum.com
post #1 of 3 Old 07-11-2003, 10:11 AM Thread Starter
Phantom5oh
Right now my 98 Sahara is on its second auto tranny and it seems to be on its way out the door again. I have had nothing but problems with it since the rebuild (shift kit added at that time) and I don't feel like rebuilding it again.
I want to change it over to a 5 speed and was wondering if anyone here has done this? Do they make a kit to do it or should I just get everything I need from a salvage yard?
What will I need other than the tranny, bell housing, clutch, flywheel, and pedal set?
Will my transfer case work? What about the stock computer, will that work with the stick?
What is the best/strongest 5 speed I can use? Should I go stock, use the Rubicon stuff, or aftermarket? I am looking to have a good 5th gear so I can actually commute on the highway with it.
98 Sahara
DANA 44 Rear, Powertrax No Slip Front, Kumho Venture 31 x 10.5 MTs
Borla Stainless Steel Header, Shift Kit w/ torque converter lockup switch, 3/8" Rock-It TB Spacer
Truck Masters Air Scoop
Windshield Mounted KC Slims
Sony Explode Deck, Kenwood Excelon Amp, 10" JL Audio Sub
- Not so stock.
03 Suzuki DR 650SE - Removed Air Silencer, Dunlop D606 Front/Rear, Moose Skid Plate and Fender Bag
81 Suzuki GS 550T
Phantom5oh is offline
post #2 of 3 Old 07-11-2003, 02:36 PM
tophillrod
tophillrod's Avatar
There are some options you can check out. Look at advance adapters - they have bell housings and everything else you could want/need, and the info to help you make up your mind. I am going to do the same thing here in a while. I am going w/ a new nv4500 kit w/ the atlas 2 for 4 thousand something. The nv4500 is what the Rubicon has (I think) and in some full size chevy and dodge trucks. It has a lower first gear and a 28% overdrive too. I would look into the advance adapters before buying anything though so you can get a picture of what is out there. HTH...
'92 YJ 4.0 HO
2" SL 2" BL 33" BFG AT's (for now)
RE quick disco's
Warn tire rack
Dana44 rear w/ Track lock
4:10 gears
135k and running strong...
tophillrod is offline
post #3 of 3 Old 07-14-2003, 08:10 AM Thread Starter
Phantom5oh
I looked into that site, but couldn't find anything for mounting to the stock I6. I think I will probably just get the stuff from the salvage yard.
What will I need?
98 Sahara
- Not so stock.
81 Suzuki GS 550T
Regear Speed change towerassoc JK Wrangler Technical Forum 3 01-08-2009 04:31 PM
What speed OK to change from 2wd to 4wd? strategydude JK Wrangler Technical Forum 26 07-31-2008 03:47 PM
6-Speed Manual Oil Change Help BPD119 TJ Wrangler Technical Forum 8 11-26-2007 10:42 PM
Speed change dieselcrackel TJ Wrangler Technical Forum 7 08-17-2006 10:07 PM
How often do I have to change the oil in the 4-speed auto? zband TJ Wrangler Technical Forum 5 11-26-2003 04:47 PM
