I have a 8.8 with the TNT truss under my jeep as well as a 2.5 inch lift and my axle is shifted to the left about 1.5 inches or so. The Track bar is set to the furthest setting I can out of the 4 holes on the truss.
Looking for a way to get that axle centered and am unable to figure out if an adjustable track bar can be made shorter then stock to pull the axle in or if they just start at stock length and go from there. Or any other option that isn't permanent, the RC 2.5 lift was just a starting block lift-wise while I learn more about my needs out in the woods and I'd rather not have any solution now become a problem when I go with another lift.
