Longer bumpstops for 33's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Longer bumpstops for 33's?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-26-2012, 08:18 PM   #1
tjallday
I am planning to upgrade my 31's to 33x10.5 this summer. I have a 2" BB but with no added bumpstops. I was wondering if I could install longer bumpstops to protect my flares without taking the whole suspension apart again.
tjallday is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 08:24 PM   #2
cheapjeep06
Yes you can. I have reached in with Channel-locks, pulled out the foam bump, then used a 1/2" ratchet with the right length extentions to reach through the coils to take out the cup bolt. Then add in extention, install with longer bolt, spray foam bump with armor-all, and use pliers again to pop it back in. Done.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2012, 08:32 PM   #3
tjallday
Isn't there a 2" longer rubber part that i could just pop in there and skip the extension?
Unread 03-26-2012, 08:38 PM   #4
cheapjeep06
Yes, yes there is. I forgot about those. I made my own extentions. Also, everyone says that when you measure for bumpstops, you don't measure the foam bump as it will compress till the steel cup hits the pad, so I don't know how that works for longer foam or poly bumps.
Unread 03-26-2012, 08:40 PM   #5
tjallday
Cheapjeep how do you like they those km2's? They are the exact tires I'm planing on getting. Will my steering components need upgraded for 33x10.5s?
Unread 03-26-2012, 08:43 PM   #6
cheapjeep06
Love em. I air down to 15-18psi ; they're like little tank treads. For steering, I currently have a ZJ tie rod. No problems turning them.
33's , bumpstops , lift , suspension lift , tires
