Longer bumpstops for 33's? - JeepForum.com
post #1 of 6 Old 03-26-2012, 07:18 PM Thread Starter
tjallday
I am planning to upgrade my 31's to 33x10.5 this summer. I have a 2" BB but with no added bumpstops. I was wondering if I could install longer bumpstops to protect my flares without taking the whole suspension apart again.
tjallday is offline
post #2 of 6 Old 03-26-2012, 07:24 PM
cheapjeep06
Yes you can. I have reached in with Channel-locks, pulled out the foam bump, then used a 1/2" ratchet with the right length extentions to reach through the coils to take out the cup bolt. Then add in extention, install with longer bolt, spray foam bump with armor-all, and use pliers again to pop it back in. Done.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #3 of 6 Old 03-26-2012, 07:32 PM Thread Starter
tjallday
Isn't there a 2" longer rubber part that i could just pop in there and skip the extension?
tjallday is offline
post #4 of 6 Old 03-26-2012, 07:38 PM
cheapjeep06
Yes, yes there is. I forgot about those. I made my own extentions. Also, everyone says that when you measure for bumpstops, you don't measure the foam bump as it will compress till the steel cup hits the pad, so I don't know how that works for longer foam or poly bumps.
post #5 of 6 Old 03-26-2012, 07:40 PM Thread Starter
tjallday
Cheapjeep how do you like they those km2's? They are the exact tires I'm planing on getting. Will my steering components need upgraded for 33x10.5s?
tjallday is offline
post #6 of 6 Old 03-26-2012, 07:43 PM
cheapjeep06
Love em. I air down to 15-18psi ; they're like little tank treads. For steering, I currently have a ZJ tie rod. No problems turning them.
33's , bumpstops , lift , suspension lift , tires
Bumpstops OahuCrawler TJ Wrangler Technical Forum 6 08-08-2011 10:12 PM
33's on 15's?--OR--33's on 17's? Rdlynch2 JK Wrangler Technical Forum 14 07-26-2011 02:17 PM
why is it taking longer and longer to start? wmeyer116 TJ Wrangler Technical Forum 9 06-29-2009 11:41 AM
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 01:55 PM
lower lift, bigger tires, longer bumpstops? BNovak TJ Wrangler Technical Forum 7 04-20-2006 09:49 AM
