Longarm lift instal question - JeepForum.com
post #1 of 8 Old 02-27-2009, 11:37 PM Thread Starter
CleanRedYj
I am putting a teraflex long arm kit on my jeep. I am ready to bolt the arms on, but I am not sure if the adjustable end goes to the frame mounted bracket, or to the axle. Any help would be great. Thanks, Jared
CleanRedYj is offline
post #2 of 8 Old 02-28-2009, 08:09 AM Thread Starter
CleanRedYj
Anyone? Im heading to the shop in a couple minutes to start putting them on. I dnt want to put them on wrong.
post #3 of 8 Old 02-28-2009, 08:21 AM
stogie25
stogie25's Avatar
I have the old style kit. My short adjustable ends are mounted on the frame side.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #4 of 8 Old 02-28-2009, 08:23 AM Thread Starter
CleanRedYj
I was leaning towards going that route. I figured it might help keep debris out of the threaded ends. THANKS!!
post #5 of 8 Old 02-28-2009, 08:29 AM Thread Starter
CleanRedYj
You seem to like your kit pretty well?
post #6 of 8 Old 02-28-2009, 03:39 PM
stogie25
stogie25's Avatar
I have modified the kit to where I like it. I installed Superlift UCA drop brackets to fix the UCA angles, and used a RE front trackbar that hinges the trackbar to flex vs. fighting itself at the joint.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #7 of 8 Old 02-28-2009, 05:25 PM Thread Starter
CleanRedYj
i'll have to look into the uca brakets. How did it work with stock uca's?
post #8 of 8 Old 02-28-2009, 06:08 PM
stogie25
stogie25's Avatar
I don't know. I put on adjustable UCA's with the lift. I put on the drop brackets a few years later. They really helped with the handling and the rotation of the axle when flexing.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
4" Lift Kit Instal Problem jkrisner TJ Wrangler Technical Forum 20 04-15-2009 02:19 PM
Trying to instal lift, Help! BucketOKarma TJ Wrangler Technical Forum 37 05-27-2008 12:02 AM
RE longarm lift for JK Bville Offroad JK Wrangler Technical Forum 1 10-21-2006 09:22 PM
tj lift instal questions y-townxj TJ Wrangler Technical Forum 11 02-04-2006 08:54 PM
lift instal issues IU98 TJ Wrangler Technical Forum 9 03-07-2005 05:23 PM
