long turnover before starting - JeepForum.com
post #1 of 3 Old 09-12-2012, 04:56 PM Thread Starter
Vicozi1234
i am usually pretty good at diagnosing a problem with my TJ but this one has me stumped... i have a 2003 I6 4.0L with about 81,000 miles on it. i had recently got my oil changed and the day after it started giving me trouble, whenever I'm parked on the slightest incline with my front higher than my rear when i go to start it, it cranks for an unusually long time before finally turning over and once its running its fine, no rough idle, no studering, nothing. but if I'm level or my front end is lower than my rear it turns right over no problem. i don't think it has anything to do with my oil think its just a coincidence that it started right after but as to what could be causing it i am out of ideas. HELP!!!
Vicozi1234 is offline
post #2 of 3 Old 09-12-2012, 04:59 PM
Schwe
Search, may be the regulator.
Schwe is offline
post #3 of 3 Old 09-12-2012, 05:14 PM Thread Starter
Vicozi1234
i was really hoping not to drop my tank but it may come down to that, thanks!
gas , hard start , problem , turnover
97 4.0 Cranks a long time before starting bigwave TJ Wrangler Technical Forum 12 07-07-2011 08:54 PM
How long before idling uses up the same amount of gas as starting it up?? TheGillz Wrangler General Discussion 16 07-02-2008 08:03 PM
Cranks a long time before starting. RH31379 YJ Wrangler Technical Forum 11 10-23-2007 02:23 PM
long crank before starting? ForkLift TJ Wrangler Technical Forum 6 10-02-2004 09:27 PM
Long starting crank and loud Alheim YJ Wrangler Technical Forum 1 07-28-2002 08:51 AM
