Long term Storage - JeepForum.com
post #1 of 6 Old 10-20-2007, 10:54 AM Thread Starter
Libtekguy
Long term Storage
Hey guys, I'm about to store my Jeep for about 15 months. It will be stored in a storage unit, not outside. What do I need to do to it before I put it away?
Thanks,
Brian
Libtekguy is offline
post #2 of 6 Old 10-20-2007, 12:26 PM
Rivka
Returning From Sabbatical
Rivka's Avatar
other folks can answer the jeep question in more detail in regards to the engine, but here are a few things that get left of some lists
and brian,
i just wanted to say thank you and wish you a safe boring deployment and a timely return. take care of yourself
As for the jeep:
i would think the best thing id to get some one to drive it every few weeks, but when that is not an option i would include in the list
• remove the battery and attach it to a AC trickle charger
• i would think about jacking it up and onto jack-stands, to take the static weight of the tires and suspension
• make sure it is clean and dry, the soft top is up if it has one but the windows are not fully closed so moisture does not get caught (if you need to close it up for some reason, there are , buy a bag of that silicon crystal cat little and pour it in a tray and set it inside, it will help absorb and stabilize moisture
• clean and flip windshield wipers away from the windshield
• if you care about the paint, wash and wax it, that will make cleaning it after you come back smoother
•grease all you greas points
folks with more engine and fluids knowledge can talk about the rest
"If you don't have time to do it right, you are going to need time to do it over."
'05 Red Flame TJ Rubi UnLtd
"Teach a man how to take his doors off and he will enjoy his Jeep for a day,
teach him to search the forums and he will enjoy his Jeep for life!"
Rivka is offline
post #3 of 6 Old 10-20-2007, 01:32 PM
Jackle
like Rivka said.......plus i'd go through and :
-change the oil
-change the anti-freeze
-change your trans fluid if its an auto (however do not change it if it has been more than 60,000miles since it was last changed)
-add some fuel stabilizer to your fuel tank
that's as far as i can think but im sure someone else will have some more
Jackle is offline
post #4 of 6 Old 10-20-2007, 01:41 PM
Rivka
Rivka's Avatar
i've always been confused by the fuel thing, some folks say drain it all out with a syphon, others say top it off and add stabilizer.
anyone who really knows there stuff wanna state pros and cons?
Rivka is offline
post #5 of 6 Old 10-20-2007, 02:37 PM Thread Starter
Libtekguy
My best guess would be to keep the tank full with stabilizer in it. I think that is to help prevent moisture from acumulating in the tank and rusting it out.
By the way, thanks for all the advice!
Brian
post #6 of 6 Old 10-20-2007, 05:12 PM
papabear1963
My jeep is almost 16 months old and as of right now it has 660 miles on it.With its age and milage you can tell it is stored quite a bit(all winter,in the garage,under a cover).Only thing I do is top off the tank with fresh gas and add the fuel stabilizer.I start it once every few months to circulate the fluids.In the spring it will get its first oil change.
2010 Camaro 1SS/RS/LS3 Supercharged
615rwhp/566rwtq.....Weekend toy.
papabear1963 is offline
Long term storage for engine walkingcrow YJ Wrangler Technical Forum 1 08-22-2009 10:46 PM
Long term vehicle storage. Flyingpirate TJ Wrangler Technical Forum 7 06-15-2009 07:01 AM
Long Term Storage HanhTheNguyen TJ Wrangler Technical Forum 4 06-04-2008 03:17 PM
Long-term storage cmulv TJ Wrangler Technical Forum 7 08-15-2007 06:43 PM
Jeep Long Term Storage towerassoc TJ Wrangler Technical Forum 7 04-09-2006 07:58 PM
