Quantcast Long Periods of Running Wide Open Throttle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Long Periods of Running Wide Open Throttle
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 04-23-2007, 12:12 PM   #1
galaxyjb
Normally I don't find the 2.5L so bad, even on the highway. But coming back from a trip this weekend into a 30 mile per hour wind while going up hill just took everything it had to try to hold 65 on the highway.
So how tough are these little engines? I had to drop down to fourth and run wide open for a good min or so at about 3200rpm while going up the hills. Temp, Oil Pressue all were normal. Is doing this going to be a problem?
TIA
JB
galaxyjb is offline   Reply With Quote
Old 04-23-2007, 01:19 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I wouldn't be concerned with that RPM at all.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 04-23-2007, 01:22 PM   #3
Combatsylvania
TIA
JB
they are meant to run... i came home yesterday after getting 31's put on my SE (mine is a 2.4 tho) and ran 3000-3500 and higher, for a lot longer.
remember, that 2.5 is in its power band above 3000rpm.. its meant to do it..
change your oil when its due, other than that.. 4 bangers are meant to scream... its actually good for them...
dont be afraid to drive it like a rental.. it will thank you for it.
PS: make sure its maintained, and put the new timing chain in when it calls for it
2006 TJ SE - Does what I want it to do.
[URL="http://www.combatsylvania.com"]http://www.combatsylvania.com[/URL]
Combatsylvania is offline   Reply With Quote
Old 04-23-2007, 01:25 PM   #4
Jerry Bransford
The steel timing chain won't need replacing until it's time for a major engine overhaul.
Getting Savvy...
Old 04-23-2007, 01:35 PM   #5
hoseclamp
In my 35' RV, it has a 460, 5.13's, when running the moutain range it will see WOT for up to 1/2 an hour, maybe more. Talk about leg cramps!!
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline   Reply With Quote
Old 04-23-2007, 03:34 PM   #6
rljsrubicon
Probably not
The last trip to the south west in my 97 4-cyl was much like you describe. I believe I put at least 2500 miles on it at WOT in 4th. I don't believe it hurt it much, but it soon just gave up at about 90K. It was a good jeep/engine and was ran hard it's entire life, so I believe it was "natural causes".. Ron
TIA
JB
rljsrubicon is offline   Reply With Quote
Old 04-23-2007, 03:53 PM   #7
LeBeteNoire
I have a 98 2.5 and the power band is from 2k to 3k any over 3k and the engine just screams with no apparent increase in power. I used to run mine past 3.5k on the highway to keep up with traffic but since having the engine blow and replacing it I try not go over 3k and to hell with keeping up in traffic, on the plus I can hear the radio now though. I don't know if running her over 3k blew the engine or not as when I swapped the engines it appeared that one of th exhaust manifold bolts was out and caught in the pipes right where the piston let go. I have 32's btw and stock gearing with a manual. she was pretty heavily run off road before I got her and maintenance was not something she had experienced; it's amazing what I know now and I should replace her with a 4.0 L that is newer and less beat up but I can't do it she's my precious.
LeBeteNoire is offline   Reply With Quote
Old 04-23-2007, 05:56 PM   #8
galaxyjb
couple of positive replies and a couple of not so positive replies...I suppose I'll just keep the hammer down and what happens, happens
Old 04-23-2007, 06:17 PM   #9
xxxflhrci
You aren't going to hurt it.
I bought a 17.5 ft I/O boat 11 years ago. My "tow rig" was a 1994 Toyota Extra Cab 4wd with the anemic 22RE 112 hp four banger. To hurt matters, the truck has 31's on it. Towing the boat on any grade requires a shift to 3rd to keep it at about 60-65. She is screaming at about 5k rpms. Back then, the truck had 30k miles on it. I told myself if the truck lasted another couple of years, I would upgrade. I still have it. It is still what I tow my boat with. I still rev it up tight on grades. It has 141k miles on it now. I wouldn't worry about reving a 4 banger Jeep up to 3-4k to make it up long grades.
xxxflhrci is offline   Reply With Quote
Old 04-24-2007, 01:23 PM   #10
bikerman02
thats nothing i used to have an 02 SE and 3000 rpm is were ya **** it just driving normally with 31's.
bikerman02 is offline   Reply With Quote
Old 04-24-2007, 01:40 PM   #11
notmyj
Part of the Three Percent
notmyj's Avatar
I had a 2wd 1985 toyota pick up with the 22re, 2 barrel, 4spd manual. That little thing would'nt die!!! The valves would float at 7200rpm, but it would just keep going. I knew a guy in college who had one in a lifted toyota on 33's. He added 10:1 pistons, a cam, and carb. That thing would run damn good!!!
The 22re will last forever.....
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone installs a S35 kit or otherwise "upgrades" a D35, an angel looses its wings."
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x8, 35's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote
Old 01-30-2011, 02:17 AM   #12
gatesjeff33
TIA
JB
You gotta run it in 4th till about 85 or so, then switch up to 5th gear and you can hit 100 mph.
gatesjeff33 is offline   Reply With Quote
Glock Forum
