Long arm upgrade - JeepForum.com
post #1 of 17 Old 06-06-2013, 02:37 PM Thread Starter
neil1982
Long arm upgrade
Looking at doing a long arm upgrade on my 98 tj. What's everyone's opinion on these what's the best bang for the buck? Also hack n taps any good?
neil1982 is offline
post #2 of 17 Old 06-06-2013, 03:30 PM
tyvanwie
Are you just planning on swapping short arms to long arms? What are you trying to accomplish?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 17 Old 06-06-2013, 04:06 PM
jefro_97tj
Do some reading on the SA LA threads on here. If I was dead set on going LA id buy clayton
jefro_97tj is offline
post #4 of 17 Old 06-07-2013, 02:47 PM Thread Starter
neil1982
I have a 4" Tera flex and I want a better street ride and better articulation off road.
neil1982 is offline
post #5 of 17 Old 06-07-2013, 03:24 PM
jefro_97tj
best thing to do is use the search bar on the home page and search for sa vs la threads. the difference In ride is subjective and the articulation is going to depend on your shock lengh and or the limiting factor in your suspension witch is most likely not your arms.
post #6 of 17 Old 06-07-2013, 03:50 PM
Imped
Imped's Avatar
Longer control arms don't guarantee either one of those.
Enjoy your research.
OlllllllO
IndyORV
Imped is offline
post #7 of 17 Old 06-07-2013, 04:00 PM
Sallad
2014 JK Wrangler
Well I went from a Rubicon Express 4.5 SuperFlex to a Clayton Pro Series 5.5 Long Arm. TO ME it was night and day in the ride. The LA drove so much better TO ME. As for articulation I might have gained a bit but not much. But that is in my opinion.
Sallad is offline
post #8 of 17 Old 06-07-2013, 04:03 PM
Imped
Imped's Avatar
Articulation has nothing to do with opinion or arm length. It is a function of shock length.
OlllllllO
IndyORV
Imped is offline
post #9 of 17 Old 06-07-2013, 04:05 PM
NotURMailman
NotURMailman's Avatar
I'm guessing that swap also involved changing springs and shocks?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #10 of 17 Old 06-07-2013, 04:05 PM
Sallad
2014 JK Wrangler
I agree! Like I said I didn't gain much. I think where I gained was my tires were not hitting my fenders anymore with the newer coils.
Sallad is offline
post #11 of 17 Old 06-07-2013, 04:07 PM
Sallad
2014 JK Wrangler
The kit I got came with new bilsteins that were the same model as the bilsteins I already had on.
Sallad is offline
post #12 of 17 Old 06-07-2013, 04:08 PM
Imped
Imped's Avatar
Well, so as to not confuse the OP, specify why you gained articulation and where the gains came from.
I'll keep going--tires hitting the fenders have nothing to do with the springs.
OlllllllO
IndyORV
Imped is offline
post #13 of 17 Old 06-07-2013, 04:10 PM
NotURMailman
So they were the same part number? Same valving?
And, no new springs?
post #14 of 17 Old 06-07-2013, 04:22 PM
Sallad
2014 JK Wrangler
I installed a brand new Clayton 5.5 Longarm my old kit was a RE 4.5. My old shocks that I had were longer because I had the up and down travel to support them. Just so happens the Clayton kit came with the same shocks as my old ones. Yes there were new coils.
I understand that you can only articulate as far as your shocks will allow. When I installed the kit I flexed it out on my forklift at work like I would with my short arm. I was worried I would roll the jeep before that rear tire would come off the ground.
Trust me I was short arm guy through and through but I got a good deal on this kit and couldnt pass it up and I am glad I got it.
Sallad is offline
post #15 of 17 Old 06-07-2013, 04:23 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Just the difference in ends alone would be night & day.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
