Long Arm Question - JeepForum.com
post #1 of 10 Old 07-13-2013, 10:20 PM Thread Starter
Trendsetter75
2010 JK Wrangler
Long Arm Question
How high of a lift would I need to use long arms for an LJ? I was thinking of going with RE 4.5 Coil Springs.
2010 JKU (6-spd)
Trendsetter75 is offline
post #2 of 10 Old 07-13-2013, 10:26 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
The lift height has no effect on length of control arms. You can run long arms with 2.5" springs.
Mail crawling.
MisfitSeven is offline
post #3 of 10 Old 07-13-2013, 10:32 PM
Necko2529
Necko2529's Avatar
Just because you have longer wheelbase in an LJ doesn't mean you can go with taller spring on stock control arms. The suspension geometry is same for both and the limits as well. This is assuming i interpreted your question correctly.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #4 of 10 Old 07-14-2013, 11:24 AM
88hatchy
Pretty sure he's asking what the minimum suspension height is for using long arms.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #5 of 10 Old 07-14-2013, 12:21 PM Thread Starter
Trendsetter75
2010 JK Wrangler
I thought the higher the lift it would cause my wheels to move inward. I notice that the RE 4.5 run higher than normal springs, and I noticed with the RE express 5.5 lift kit comes with long arms. I want to go a little higher because it seems what ever springs I throw into my LJ the Jeep doesn't look high enough for me.
Since someone brought up someone can have a 2.5 lift with long arms why is that? Not being sarcastic I just don't know why.
2010 JKU (6-spd)
post #6 of 10 Old 07-14-2013, 12:47 PM
_KONG_
Just read this post over and over again until it makes sense. If it still doesnt, go look at your jeeps suspension then come back and read it again
_KONG_ is offline
post #7 of 10 Old 07-14-2013, 12:50 PM
freeskier93
I think the better question to ask is why do you think you can't? What would physically prevent you from doing it?
freeskier93 is offline
post #8 of 10 Old 07-14-2013, 01:19 PM Thread Starter
Trendsetter75
2010 JK Wrangler
What are the benefits of running long arms oppose to short arms then?
2010 JKU (6-spd)
post #9 of 10 Old 07-14-2013, 01:22 PM
freeskier93
That's the golden question that's going to turn this thread into a **** fest.
This is probably the most debated topic on this forum. Do some searches, you'll find your answers.
post #10 of 10 Old 07-14-2013, 01:30 PM
Ironhead
long and short is relative. its what is the best setup for your rig and what you do. from everything that i have read, I am staying with stock mounts or short arms until i can fab up some custom mid arms and all new mounts. custom mid arms with raised mount points seems to be the best option for arms, IMO
Ironhead is online now
