Locking my front axle. A few questions - JeepForum.com
post #1 of 6 Old 03-18-2006, 06:38 PM Thread Starter
quitelifted
quitelifted's Avatar
I have a HP dana 30 in my TJ and will be re gearing it soon to match the back. I was thinking of putting in a lunchbox locker at the same time. Ausie locker is my first choice I think.
My question is: I have seen that You can't put one in the front of a vehicle that has all time 4wd. My Tj as you know is always locked and spinning and then the t-case shifts into 4wd. Does this count as all time. Would I need to use manual locking hubs up front to lock it with a lunchbox?
quitelifted is offline
post #2 of 6 Old 03-18-2006, 06:53 PM
Expat
Frequent flyer
Expat's Avatar
No a TJ is NOT full time because the front driveshaft receives no power when in 2H. A locker works fine in the front, no manual hubs needed, go for it
05 RME Fire Red
3.5" RE springs, JKS F&R adj track bars, JKS adj CAs (all 8), OME LT shocks, JKS quicker discos, JKS 1.25" BL, MORE BP MML, 35" Cooper SSTs on 057 Eagle Alloys, 4.56s Detroit lockers, Alloy USA front and rear axles, Currie HD steering, 52" Hanson front bumper, Warn 9.5ti with in-cab control, Kilby steering box skid, Jeeperman rear bumper/tire carrier, Jeeperman trail skidz, 33 Eng TT, JB SSSYE, TW driveshaft, and lots more........
2007 WK Overland Steel Blue..wifes
1997 ZJ Laredo...sons
2004 GMC 2500 HD Duramax Diesel..My TV and DD and Lance camper carrier
2003 Chaparral 223 deck boat
Originally Posted by kjp98TJ
drop the purse, and hit it.
Expat is offline
post #3 of 6 Old 03-18-2006, 06:59 PM Thread Starter
quitelifted
What I was worried about is that the drive shft and inner axles spin all the time even though their not being powered by the t-case.
post #4 of 6 Old 03-18-2006, 07:06 PM
Expat
Frequent flyer
Expat's Avatar
I understand, but without power applied from the driveshaft the locker is transparent.
05 RME Fire Red
Expat is offline
post #5 of 6 Old 03-18-2006, 07:34 PM Thread Starter
quitelifted
Cool. thats what I wanted to hear. Thanks
post #6 of 6 Old 03-18-2006, 08:39 PM
Lcars
Nanners...MMMM..Toasty
Lcars's Avatar
The lunchbox locker will change how it drives in 2wd and 4wd. In 2wd you do notice some pull and an occasional bang. Since the front is spinning it binds ever now and then. True, no power is being sent from the transfer case but I have noticed a difference. In 4wd, don't plan on turning very well. It will climb up and over almost anything but you have to fight it to turn. I am pulling it out of my front end and replacing it with a selctable locker. That way I can turn it off when in 4wd when I don't need it. It is great to have when you need it, but is more of a pain when you just want to play in the mud.
<--- I got a big Dancin Nanner
- Jeep Encyclopedia
Originally Posted by JungleLarry
THAT'S MY DICK IN YOUR B*TT!
(Edited for content.)
N7GTJ
View my Paddock Pool construction nightmare at
Lcars is offline
hood latch opinions needed. locking side latches vs locking front Snydermann TJ Wrangler Technical Forum 19 06-07-2014 04:39 AM
Could somebody list the plus's and minus's of locking front axle permanently on YJ gary1 YJ Wrangler Technical Forum 9 01-27-2010 06:13 PM
LSD For Front Rubicon Locking Axle my05rubi TJ Wrangler Technical Forum 27 12-22-2008 12:23 PM
locking hub-front axle disconect Goobersbro YJ Wrangler Technical Forum 4 11-13-2008 10:32 PM
Locking front axle and drivability Pointblank TJ Wrangler Technical Forum 8 11-17-2006 07:03 PM
