locking hubs for tj dana 30 - JeepForum.com
post #1 of 39 Old 09-08-2010, 08:44 AM Thread Starter
ClassicRiderhp
do they make locking hubs for a dana 30 5x4.5 or is the conversion necessary to install locking hubs. The only thing i could find was a 1200$ locking hub conversion kit that goes from stock 5x4.5 to 5x5.5 but not locking hub that will fit to a tj d30
2001 Wrangler TJ, 4.0L, 5 Speed, 3in BDS suspension lift kit, 33in Duratracs, front ARB bull bar, rear XRC bumper
ClassicRiderhp is offline
post #2 of 39 Old 09-08-2010, 09:00 AM
bairy
You found it.
Why do you want locking hubs? or rather, unlocking hubs.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #3 of 39 Old 09-08-2010, 09:01 AM
mdm
Farm Wheeler
The only way to install locking hubs on the TJ D30 is to install a conversion kit. Warn has one for around $1200 and Mile Marker has one for around $700.
Why do you think you need locking hubs?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 39 Old 09-08-2010, 09:17 AM
tjdriver
the warn kit is no longer avail. you may find a few here and there, but warn is not manufacturing it anymore. randy's ring and pinion purchased the rights or whatever for the kit. i dunno bout the mm kit. i have the warn kit on mine with the small hubs.
tjdriver is offline
post #5 of 39 Old 09-08-2010, 09:21 AM
JA66
Probably because the unit bearings suck, and if you break a front axle, you can unlock the hubs and drive, instead of taking it apart.
JA66 is offline
post #6 of 39 Old 09-08-2010, 09:23 AM
mdm
Farm Wheeler
Originally Posted by JA66 View Post
Probably because the unit bearings suck...
For something that "sucks", unit bearings do a fine job for the vast majority of Jeep drivers.
mdm is offline
post #7 of 39 Old 09-08-2010, 09:45 AM
tjdriver
true, but once you start adding big tires and offset wheels you bit a lot more strain on the hubs. i love my warns and wouldn't dream of switching back to reg hubs, but to each his own.
tjdriver is offline
post #8 of 39 Old 09-08-2010, 09:47 AM
tjdriver
btw, i just read the write up for the warn hub conv on stu's site. very good info on the pros and cons of having/not having the conv. there is also a scenario with pics at the end of the article.
tjdriver is offline
post #9 of 39 Old 09-08-2010, 09:47 AM
theducksguts
Milemarker is about all there is new out there. Still a few Warn kits floating around. The unitbearings work fine for me. With the cost of some of these kits it might be cheaper to swap in a larger steering axle.
Check out my
theducksguts is offline
post #10 of 39 Old 09-08-2010, 09:53 AM
CCGRUNT0331
link to site?
2000 TJ Sport: SOLD!
2008 JKU Rubicon: aka 'Bruiser'
CCGRUNT0331 is offline
post #11 of 39 Old 09-08-2010, 09:57 AM
Ghaniba
I'd bet this is it:
Warn Hub Conversion - 1
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline
post #12 of 39 Old 09-08-2010, 10:00 AM
CCGRUNT0331
Gracias
post #13 of 39 Old 09-08-2010, 10:01 AM Thread Starter
ClassicRiderhp
Same as said above. I want locking hubs so I can free the axle if I blow my Dana 30. Why else would someone get locking hubs besides preserving axle and gear life with them being free for street driving
post #14 of 39 Old 09-08-2010, 10:07 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Do tell.
When's the last time you disassembled a hub, spindle, knocked the races loose and repacked all the bearings? How long did that take? 2-3 hours?
It takes 10 minutes to pull the entire unit bearing off and install a new one.
I've disassembled a hub on a buddy's truck before...man that sucked. I'd much rather have unit bearings.
go to the junkyard, buy a set of used shafts and unit bearings. saw off the ears on the inner shaft. bingo, cheap lockouts.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #15 of 39 Old 09-08-2010, 10:13 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You are very unfamiliar with breakage and hub conversions, aren't you?
Three things break in the front axle with the small conversion.
Hubs, and although you could drive that way, do you really want all the mud/dust/dirt/whatever getting into the outer bearing? Not really, and it's also very rare that if you are in a place where a hub breaks, you don't still need 4 wheel drive. So, you're fixing it to get home.
U-joints- As above, when and where would you break one that you don't still need 4 wheel drive? Yep, you're fixing it or getting towed to where you can drive in 2 wheel drive.
And finally, the inner axle breaks and yep, you guessed it, tow until you can use 2WD or fix it.
I am a big fan of hub conversions, I own or have owned many many of the Warn versions for years and still currently have at least 2 complete ones floating around. We've also run the crap out of them in JV where they are very nice to have.
Nowadays though, the only good reason to own one is so you can finish out the trail in 4wd with a bent front driveshaft and then unlock the front to get back to camp or home.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
Locking hubs on a d-30 YYJ87 YJ Wrangler Technical Forum 6 12-10-2009 05:12 PM
Locking Hubs Pyroteknik701 TJ Wrangler Technical Forum 5 05-14-2007 10:00 PM
locking hubs bluejeep00 TJ Wrangler Technical Forum 2 01-22-2007 02:14 PM
Locking hubs wheeldawg TJ Wrangler Technical Forum 18 09-18-2006 05:22 PM
What do locking hubs do??? AlaskanYJ YJ Wrangler Technical Forum 5 08-04-2006 02:01 AM
