Locking differential on 2005 Rubicon won't lock! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Locking differential on 2005 Rubicon won't lock!
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 05-27-2008, 11:02 AM   #1
thekahuna1
The rear locker light just continues to flash and the locker does not lock. I checked the hoses and they are fine. What else should I check? How do you check the funny three prong fuse in the fuse box? Thanks for the input!!!
thekahuna1 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2008, 11:05 AM   #2
carpekd
Are you sure your air pump is kicking on? will your front locker engage?
carpekd is offline   Reply With Quote Quick reply to this message
Unread 05-27-2008, 11:26 AM   #3
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Does the compressor pump? Try discounting the hose to the rear and engage locker. The pump should pump until you put your finger over the outlet. You took off the rear diff cover and check the hose connection inside? Pretty common problem with Rubi lockers.
SAVVY OFF ROAD - Overall Winner of the King of the Hammers Everyman Challenge FOUR years in a row!
Email me for the fastest response: gman@savvyoffroad.com
Like us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee Lifetime Guarantee - See Here
http://www.savvyoffroad.com
Unlimited Black Hole - The Ultimate LJ
Savvy Spartan 2004 LJ
2014 JKU Test Mule
FOUR years in a row! KOH Mod Killer Build
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote Quick reply to this message
Unread 05-27-2008, 11:31 AM   #4
newracer
are you in 4 low?
newracer is offline   Reply With Quote Quick reply to this message
Unread 05-27-2008, 11:47 AM   #5
Zachs
dealership...
Isn't the "funny 3 prong fuse" a relay? If so, hit the switch and it should click.
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline   Reply With Quote Quick reply to this message
