Locking differential on 2005 Rubicon won't lock! - JeepForum.com
post #1 of 5 Old 05-27-2008, 10:02 AM Thread Starter
thekahuna1
The rear locker light just continues to flash and the locker does not lock. I checked the hoses and they are fine. What else should I check? How do you check the funny three prong fuse in the fuse box? Thanks for the input!!!
thekahuna1 is offline
post #2 of 5 Old 05-27-2008, 10:05 AM
carpekd
Are you sure your air pump is kicking on? will your front locker engage?
carpekd is offline
post #3 of 5 Old 05-27-2008, 10:26 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Does the compressor pump? Try discounting the hose to the rear and engage locker. The pump should pump until you put your finger over the outlet. You took off the rear diff cover and check the hose connection inside? Pretty common problem with Rubi lockers.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #4 of 5 Old 05-27-2008, 10:31 AM
newracer
are you in 4 low?
newracer is offline
post #5 of 5 Old 05-27-2008, 10:47 AM
Zachs
dealership...
Isn't the "funny 3 prong fuse" a relay? If so, hit the switch and it should click.
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
Rubicon differential lock override? Pointblank TJ Wrangler Technical Forum 3 09-04-2007 08:22 PM
03 Rubicon rear differential lock-up rubicon-tom TJ Wrangler Technical Forum 4 08-22-2007 05:16 PM
How do I know if a 2001 TJ has the locking rear differential? Dr. Romney TJ Wrangler Technical Forum 26 04-10-2007 08:02 AM
Locking Differential jojojojo JK Wrangler Technical Forum 15 01-21-2007 06:57 PM
