Locking Differentail - Page 2 - JeepForum.com
post #16 of 21 Old 03-24-2014, 12:45 PM
CharlieHo
Originally Posted by TomJeep21 View Post
Currently I only have Dana 33's I was looking at the Dana 44's to drive the bigger tires but if I stay a smaller like the 33's you think I still need to get a stronger axel?
Eh, you have a Dana 30 in the front. You have either a Dana 35 or 44 in the rear.
The D35 is not a good axle to throw large tires or lockers at.
The other two are OK.
http://www.jeepforum.com/forum/f9/st...1/#post4118396
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
post #17 of 21 Old 03-24-2014, 12:46 PM
Jwinecoff00
There is no such thing as Dana 33's. You most likely have a Dana 35 rear axle, and a Dana 30 front axle. If you stay on 33's, those will be ok. You step up to 35's and that Dana 35 rear axle will be at it's breaking point.
2006 Solar Yellow LJ Rubicon
Build Thread:
Follow me on Instagram @Jwinecoff
Jwinecoff00 is offline
post #18 of 21 Old 03-24-2014, 12:46 PM
biffgnar
biffgnar's Avatar
You have a Dana 30 in the front and probably a Dana 35 in the rear. As long as you don't drive like an idiot they should be OK with 33s, although I would not lock the D35 with any size tire.
Romney in 2020!
biffgnar is offline
post #19 of 21 Old 03-24-2014, 01:37 PM Thread Starter
TomJeep21
If I do plan/ever get to putting lockers on do I have to do it to both the front and back or would I be able to get away with only one?
TomJeep21 is offline
post #20 of 21 Old 03-24-2014, 01:41 PM
Jwinecoff00
It's completely up to you. The front and rear axles are completely separate from one another. You could lock both, just the front, or just the rear. However, BOTH axles must be geared to the same ratio or your drivetrain will explode the instant you put it in 4WD. Obviously, this only matters if you get into regearing the axles to compensate for larger tires.
Build Thread:
post #21 of 21 Old 03-24-2014, 02:00 PM
McLovin
I think a good place to start with would be to add a 2" budget boost and 1.25" body lift, add some 33's and drive it, see what you think. If you want more off road capability then add a lockright style locker to the front end. This is relatively inexpensive, if you want to go bigger later you can sell the budget boost, and be out only a small amount. A TJ with 33's and some lockers is pretty dang capable, and you would probably be really surprised at where it will take you.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
differential , tj , wrangler tj
