Lockers...air vs electric - JeepForum.com
post #1 of 46 Old 04-20-2009, 01:22 PM Thread Starter
Jeep Kid
I'm curious what are the pro's and con's of the electric lockers and air lockers? I know the pro's of having a selectable locker, but why the hassel of having to route air lines and mounting compressors when it seems it would be much easier just to have a electric locker? Thanks in advance
Jeep Kid is offline
post #2 of 46 Old 04-20-2009, 01:28 PM
NotURMailman
NotURMailman's Avatar
It's really just a personal prefferance issue. IMHO it seems that the air units would be a tad stronger and likely last longer. I went with ECTEDs for the LSD action when off, and will openly accept the need to replace clutches eventually. If it weren't for wanting the LSDs I would have gone ARB.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 46 Old 04-20-2009, 01:50 PM
RogueSpear2023
From what I have read the clutch locker are not as strong as a regular locker is, the electrics are on the new JK are being mad with mounts for a TJ now, The problem is there are really any great electrics right now like there are for the air like ARB, it's really a preference thing.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 46 Old 04-20-2009, 02:02 PM
gribbles
the Eaton E locker gets really good reviews, and running a compressor and air lines is not a difficult thing to do, no more difficult then running wires for an electric locker
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #5 of 46 Old 04-20-2009, 02:05 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its mostly preferance.
I prefer electric because its what I am familiar with.
Electric is very easy to install. No compressor is needed which makes it cheaper and its one less part to fail.
Originally Posted by RogueSpear2023 View Post
...The problem is there are really any great electrics right now like there are for the air like ARB, it's really a preference thing.
Eaton makes a nice E-Locker.
Wheelin98TJ is offline
post #6 of 46 Old 04-20-2009, 02:36 PM Thread Starter
Jeep Kid
Thanks to everyone for the replies. That pretty much answered my question! Good stuff to know for future builds...
Jeep Kid is offline
post #7 of 46 Old 04-20-2009, 04:16 PM
WAKIZASPEED
You could also consider OX lockers. They just have a cable that manually locks and unlocks.
Just a thought.
WAKIZASPEED is offline
post #8 of 46 Old 04-20-2009, 04:53 PM
MayRoll
A good friend of mine runs Auburn's ECTED at both ends of his rig. I can only compare them to my factory Rubicon air lockers. I like the fact that when you hit the button, there is an immediate action within the locker. When you need the locker it's there instantly. However, disengaging can be a pain in the ***. Unlocking usually requires serpentining on a high traction surface. Really annoying, especially with the front.
MayRoll is offline
post #9 of 46 Old 04-20-2009, 05:55 PM
base shakers
as someone who has owned both auburn ecteds and eaton elockers i can tell you there is no comparison. auburn ecteds are slow to lock up, slow and noisy to unlock, slip when you have reasonable traction, break easily (4 in 18 months), the limited slip is so mild it might as well be open, and auburn's customer service is horrible. eaton elockers lock immediately, unlock silently, and i have had no issues yet with breakage. yes, you might save a few hundred per axle with auburn ecteds but you will pay for it with replacement parts in no time. you've been warned!
'05 LJ, ~4" lift, 35X12.5 Toyos, 16" beadlocks, HPD44, HPD60, 4-speed Atlas, 4.6L stroker
base shakers is offline
post #10 of 46 Old 04-20-2009, 06:07 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
I went with the ARB route. it's more expensive but it's rare to hear anyone having a problem.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #11 of 46 Old 04-20-2009, 06:15 PM
jeepwcrazy
jeepwcrazy's Avatar
I wouldn't say it's rare, but I would say that the ratio of failure to the amount of people that have them is pretty good. I went to the Molina Ghost run this past weekend and I know of 2 different ARB failures.
jeepwcrazy is offline
post #12 of 46 Old 04-20-2009, 06:46 PM
Digger 5
I really believe that electric actuation is superior but not many electric lockers can meet ARB's strength or quality.
Ecteds are junk. ANYTHING but Ected. They don't really lock as they just add addional clutch pack pressure that can be overcome with good traction. The axle engagement is a joke (9/16" WTF!) in the unlocked mode and is prone to stripping axle shafts. Good idea- very poor execution.
Eaton ELockers can be anywhere from great to shaky depending on the model. The new Dana 30 and 35 models are great units that my customers have loved. These units are 3 or 4 pinion designs are will outlast the ring gear. They have a collar style engagement that works very well and has proved durable. The Dana 44 model also uses the collar style actuation but has a 2 pinion design. It works very well but is weaker than 4 pinion competitors like ARB or OX. The 8.8 ELocker uses a pin style engagement that is prone to rouding pin ends. It is also a 2 pinion design. Eaton is working on a new design for 44 and larger models that should cure all the strength issues.
OX Locker now offers an electric version of their locker. Unfortunately is still uses a cable and uses a GM axle actuator to push and pull the cable.
The new JK Lockers (4 pinion) have been getting good reviews but can't be retrofitted to standard 44 cases.
For Dana 30 and 35 models I recommend ELockers but for nearly every other application I recommend ARB.
Jeepin's not a hobby, it's a lifestyle!!
Digger 5 is offline
post #13 of 46 Old 04-21-2009, 02:35 AM
jeep2008
First question:the rubicon locker is also limited slip when unlocked and electrical.Is it worth it?
Second question:The ELocker for the dana35 like this one http://www.quadratec.com/products/16100_1014.htm can it be found for less than that anywhere else?Does anyone have a dana35 ELocker with upgraded 27spline axles?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #14 of 46 Old 04-21-2009, 06:29 AM
Pillswoj
1. The TJ Rubicon locker is air not electric, I believe the JK Rubicon is electric but will not fit in a TJ Dana 44.
2. There is always someplace cheaper then Quadratic and the one you show is the 30 spline version. try Google.
Friends don't let Friends run Bosch
Pillswoj is offline
post #15 of 46 Old 04-21-2009, 06:38 AM
Wheelin98TJ
JEEP FREAK
The part # for the 27 spline D35 Eaton ELocker is 19821-010.
Electric Lockers coryweng TJ Wrangler Technical Forum 37 12-19-2007 07:00 PM
electric or air lockers? drummerwookie TJ Wrangler Technical Forum 2 12-03-2006 09:52 PM
Update on Electric Lockers for D44 4crnrsco TJ Wrangler Technical Forum 7 11-21-2006 08:28 AM
electric lockers need help ranger 66 TJ Wrangler Technical Forum 7 11-01-2006 04:53 PM
Lockers..Electric or Air? TJ specific! TorxMonkey TJ Wrangler Technical Forum 43 10-14-2005 05:47 PM
