lockers in 97 2.5l? - JeepForum.com
post #1 of 2 Old 10-10-2010, 04:20 PM Thread Starter
spreadneck
lockers in 97 2.5l?
i bought my jeep a few months ago and it is my first one. i am wanting to put lockers in it then buy bumpers/winch in the next few months, but i have been reading a lot of forewarning against lockers in the dana 35 rear end. what would be the best route to go? it is my DD but i take it offroad at least 4 times a month: mostly trailriding with a lot of mud and minimal rock crawling. any info would be great im just tryin to do some research before i spend the money
spreadneck is offline
post #2 of 2 Old 10-10-2010, 04:34 PM
06WranglerX
If you wish to lock the D-35 safely you will need chromo shafts, I recommend Superior shafts, very good CS and quality products. Many times you can find a kit, Shafts and a locker one price here is a good example, Superior Axle Super 35 Kit with Detriot Locker
However, keep in mind that does not remove the C clips only stronger shafts and a locker, if the shaft did let go it can walk itself out of the tube and you could possibly lose a tire. If you wanted further security, you can upgrade even further with shafts a locker and the C clips removal product that Superior also offers.
To lock the front an Aussie, or a lock rite, drop in locker is affordable for the weekend wheeler. Keep in mind though if your in the snow belt at all, a front auto locker like the ones I mentioned are not recommended. Many individuals who live in areas like this use selectable lockers, arb, ox, eaton. Also with a front locker avoid getting on the throttle and turning the wheel, u joints tend to go boo when you turn the wheel and more force in directed to them, chromo shafts and full circle clip u joints help with this. Good luck.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
dana 35 , lockers
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
No lockers JeSimmers Wrangler General Discussion 9 09-23-2008 07:48 PM
OX Lockers VS ARB tjturtle TJ Wrangler Technical Forum 11 04-14-2007 10:44 PM
Lockers? surfgod04 TJ Wrangler Technical Forum 5 02-08-2005 06:39 PM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 02:45 PM
