locker, rockers, or gears - Page 6 - JeepForum.com
post #76 of 79 Old 09-20-2011, 03:32 PM Thread Starter
FarmerJohn
If only they would have put D44's in the rear of all TJ's the world would be a happier place.
FarmerJohn is offline
post #77 of 79 Old 09-20-2011, 03:50 PM
CT99XJ
8.8's are easy swaps. Don't waste money on a 35, /thread.
'96 ZJ, 318 w/stupid things, 5.5" and 33's, Clayton stuff, Bilstein, 1-ton, 2.5" Y-pipe back
CT99XJ is offline
post #78 of 79 Old 09-20-2011, 03:54 PM
jds79cj
Originally Posted by andy02 View Post
A lunchbox in the rear of a TJ and the rear of your XJ are two totally different animals. The difference is in the wheelbase. Having tried it with two different TJs and a 91 XJ, the difference is night and day. I would never suggest a lunchbox in the back of a TJ.
I would have to say agree with the no lunchbox locker in the rear of TJ especially if it is a five speed. I put one in my TJ and it has made it very interesting to drive under acceleration and while turning. While accelerating and shifting it causes the rear end of the jeep to shift around I guess from the loading and unloading of the locker. If you try to make a sharp turn and do not take it out of gear just the resistance of the gears will keep the locker engaged (even with the clutch pushed) and you jeep will buck and chirp the tires.
I have a Sparton so maybe a Aussie or lockrite wiould be different but I am already making plans to sell my D44 to pay for an 8.8 with a selectable locker.
jds79cj is offline
post #79 of 79 Old 09-20-2011, 08:37 PM
DBibeau855
Easy answer. Locker. You'll have to reset the gears anyway, so get new ones to reclaim that power band. Anything worth doing is worth doing right, save up and get a selectable locker for the rear and an S35 kit, or an 8.8 if you dont mind losing some ground clearence in exchange for strength. In the end its cheaper to do something right the first time as opposed to the second time. This true for jeeps, college courses and marriages as well.
55w 6000 DDM HIDs. 130 Watt KC daylighters(X4). AA SYE, Tom Woods CV drive shaft, currie upper rear control arms and 33X12.5 KM2s. Rubicon Express 3.5 inch lift. Supperior D35 30 Spline C clip eliminator, Ox locker, 4.88 gears. HP D30 W/ detroit locker w/ currie adjustable arms. Currie front Anti Rock. Adjustable front and rear track bars,
DBibeau855 is offline
gears , locker , rocker guard
locker and gears. baellis1 TJ Wrangler Technical Forum 31 03-13-2011 08:51 AM
need to buy gears and arb locker ClassicRiderhp TJ Wrangler Technical Forum 18 04-28-2010 10:10 AM
4.56 Gears & Ox Locker VnutZ TJ Wrangler Technical Forum 5 08-04-2009 10:38 PM
4.88 gears ox locker ? beerking1 TJ Wrangler Technical Forum 13 01-01-2009 11:35 AM
Gears & Locker - What shall I do? Marshmellow YJ Wrangler Technical Forum 3 07-13-2002 11:00 AM
