locker, rockers, or gears - Page 5 - JeepForum.com
post #61 of 79 Old 09-18-2011, 04:08 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by FarmerJohn View Post
maybe a new diff cover for the 30 since I will be taking it off anyways, any good recommendations for a good cheap D30 cover?
I was happy with the Solid diff cover I had on my YJ. http://www.solidaxle.com/productcart...1&idcategory=7
Jeffro06 is offline
post #62 of 79 Old 09-18-2011, 05:36 PM
TonysTJ
^^^^ That is so funny and so true.
you should just get a new axle.
Whats even more funny are all these "get a new axle " comments
....period...just get a new one
Originally Posted by joe_jeep View Post
get a rear axle. d44 or 8.8 or 9.
To the OP, they are trying to say that your Jeep sucks and YOU need a monster truck instead of your current rig.
If your gonna spend $1000 on your D35 you might as well just purchase Gravedigger
TonysTJ is offline
post #63 of 79 Old 09-18-2011, 08:11 PM
EricsGreen98Tj
Originally Posted by jeepinmichguy_ View Post
Because 33's will get you so much further.
Having driven both....Yeah 33's do go better in the mud, on trails, and I'm pretty sure on rocks too. They are WIDER and the offer 1" more of ground clearance. But I forgot who I was talking to
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #64 of 79 Old 09-18-2011, 08:14 PM
EricsGreen98Tj
BTW- Watch when you buy an aftermarket diff cover. There seems to be alot of issues with trac bar clearances when using an aftermarket cover. Mabey look into one like the Warn or RuggedRidge that is a half cover used along with your stocker.
post #65 of 79 Old 09-19-2011, 11:56 AM
CT99XJ
You're an idiot.
Spending $1000 on a D35 is pointless, when chances are you could spend LESS on a better axle.
'96 ZJ, 318 w/stupid things, 5.5" and 33's, Clayton stuff, Bilstein, 1-ton, 2.5" Y-pipe back
CT99XJ is offline
post #66 of 79 Old 09-19-2011, 02:21 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #67 of 79 Old 09-19-2011, 02:54 PM
EricsGreen98Tj
:d
post #68 of 79 Old 09-19-2011, 03:34 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by CT99XJ View Post
You're an idiot.
I wonder what is stronger, your 8.25 with chromo shafts or a D35 with a S35 kit installed?
Wheelin98TJ is offline
post #69 of 79 Old 09-19-2011, 03:57 PM
EricsGreen98Tj
That's a very good question. Do you happen to know the answer to that?
Also that "spending $1000 on a D35" also gets you a full case locker or full case limited slip(TruTrac) + some aftermarket shafts(Superior Evolution Series 27 spline shafts are $200 a set online). And I KNOW I have read MrBlaine post that hed rather run a Super35 than a D44 with stock shafts.
It really comes down to if you can do the work to set up and swap an axle housing into you Jeep YOURSELF! IF you can than you may be able to do it cheaper than a Super35 kit or mabey not. At least with the Super Kit you know what your getting yourself into and you dont have to pull the housing plus you'll be a little stronger than a stock d44.
post #70 of 79 Old 09-19-2011, 08:05 PM
FarmerinVA
+1. And brand-new internal components including bearings, a whole lot less install work, no need for a different size driveshaft ...
Eric, I don't think a TrueTrac is available in the 30-spine for the Super 35 kit, though. I assume this is because there isn't enough of a market for it, because people wanting a TrueTrac wouldn't need the Super 35, they can stick with the stock 35 or just upgrade the shafts (that's what I did).
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #71 of 79 Old 09-19-2011, 09:11 PM
EricsGreen98Tj
^^Thats why I said that Superior Evo(mabey Discovery) shafts in 27 splines are $200 online(for use with the TruTrac). they say 30% stronger than stock too(same as the Super35 kit). that way you can keep your stock 27 spline shafts for spares. I really think this is what gonna happen to my Tj when I get some loot saved up. I already have 4.10's with my 4 banger and want to/am going to swap an NP435 in place of my AX5, so I dont think I'm gonna need to regear the axles(due to the non-overdrive tranny). Just need traction aids and some stronger shafts at the moment.
BUT - I wonder if anybody has 4 linked the rear of a Tj and used their (upgraded) D35........seriously.
post #72 of 79 Old 09-19-2011, 09:13 PM
EricsGreen98Tj
As I will never go larger than a 35" tire...and keep my 4cyl forever!!!
post #73 of 79 Old 09-19-2011, 11:23 PM
Wheelin98TJ
JEEP FREAK
...BUT - I wonder if anybody has 4 linked the rear of a Tj and used their (upgraded) D35........seriously.
Look up user name nevermonday.
post #74 of 79 Old 09-20-2011, 12:18 PM
CT99XJ
I really don't care who they are, anyone who would rather run a 35 needs their DNA bleached from the wheeling gene pool.
CT99XJ is offline
post #75 of 79 Old 09-20-2011, 12:41 PM
Wheelin98TJ
JEEP FREAK
Use your brain and it should make sense to you.
Most TJs come with the 35.
TJ D44s are hard to come by.
Custom, bolt-in axle assemblies are expensive.
Axle swaps are difficult for some people if you have to setup the brackets for the TJ coil and link suspension.
Its not that people would rather run the 35, its because its what they have and it can be worked with when your talking about 33" tires.
gears , locker , rocker guard
locker and gears. baellis1 TJ Wrangler Technical Forum 31 03-13-2011 07:51 AM
need to buy gears and arb locker ClassicRiderhp TJ Wrangler Technical Forum 18 04-28-2010 09:10 AM
4.56 Gears & Ox Locker VnutZ TJ Wrangler Technical Forum 5 08-04-2009 09:38 PM
4.88 gears ox locker ? beerking1 TJ Wrangler Technical Forum 13 01-01-2009 10:35 AM
Gears & Locker - What shall I do? Marshmellow YJ Wrangler Technical Forum 3 07-13-2002 10:00 AM
