locker, rockers, or gears - JeepForum.com
post #1 of 79 Old 09-15-2011, 05:29 PM Thread Starter
FarmerJohn
So I'm about to get some new parts for my jeep but can't really decide what to get right know. Right know I have a 2.5 RC lift a winch and 31'' tires. I plan on getting 33''s in a month or two so I'm going to need to regear soon (only have 3.07 now). I'm looking into going ahead and getting some of the stuff to regear but I can't get all of it right know (I plan on doing the work myself), if I don't do that I was going to pick up some rocker guards or maybe a aussie locker. What do you think would be my best choice, I do mostly moderate trails most of the time I haven't needed a locker but there has been a few times.
FarmerJohn is offline
post #2 of 79 Old 09-15-2011, 05:45 PM Thread Starter
FarmerJohn
post #3 of 79 Old 09-15-2011, 05:54 PM
Jeffro06
Jeffro06's Avatar
Personally I'd go ahead and get all the armor (and other things) you want before upgrading the tires and gears. That's the route I'm going. I plan on doing all I can to my jeep, in the way of armor, control arms, cage, and things like that, then I'll step up to 35's and re-gear.
Jeffro06 is offline
post #4 of 79 Old 09-15-2011, 05:54 PM
robncar
robncar's Avatar
Do you have experience installing gears in a TJ? I think I'd go with gears for those 33's and see how it goes. Since an Aussie is a "lunchbox" locker, it can be added at any time without a gear setup. I'd only put an Aussie up front though, not in the rear.
Sent from DROID2
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #5 of 79 Old 09-15-2011, 08:58 PM
FarmerinVA
You've never needed a locker? I'm puzzled by that statement. When you say "moderate trails" what do you mean?
Or do you mean that you know your Jeep's current lockerless limits so you drive within them and that's why you don't get stuck (smart).
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #6 of 79 Old 09-15-2011, 10:49 PM Thread Starter
FarmerJohn
Sent from DROID2
I know a few people who have done quite a few regears not sure about TJ specifically though, and I wasn't planning on putting a Aussie in the rear not on a D35 anyways, I'm kinda leaning towards getting the gears first cause 33's on 3.07 will be dreadful, but I can't get every thing right now is the only thing.
I have been in situations that would have been alot easier with a locker but I managed. I try to avoid trails that I will have to much trouble with I have hit alot of the moderate trails at Windrock without to much trouble.
post #7 of 79 Old 09-15-2011, 11:43 PM
2006_Sport
This. Having armor means you can do fun stuff
2006_Sport is offline
post #8 of 79 Old 09-16-2011, 07:39 AM
2ACR
That's Right I Support
2ACR's Avatar
If you're going to slide over objects at any point you are better off with armor. If you are like me and don't really see rocks (I see washed out roads and hill climbs. I don't mean a dirt road. Full articulation kind of roads. I guess you would just call it a path in the woods with a little extra space between the trees) go with new gears plus LSD in the rear and auto locker in the front. If you do all the work yourself you will save about 500 in cash after the purchase of LSD and auto locker. If you do the regear yourslef but can't afford the auto locker for the front at least get the LSD in the rear as part of your regear. It won't cost that much more.
Originally Posted by jr03 View Post
And when you can't find the wrench your holding in your hand, it's time for a break:rofl:
Jeep Jedi in Training.
2ACR is offline
post #9 of 79 Old 09-16-2011, 08:05 AM
danielbuck
1946 CJ2
I would probably do the gears first, then the locker(s), and then the rockers last.
I don't really hit my rockers very often, I hit my gastank skid, rear bumper and transfer case alot (and the control arm mounts and body mounts!), but not the rockers so much, and I really only hit that stuff somewhat more difficult rock trails, I usually don't hit anything on moderate trails. If you are only doing moderate trails, you probably don't need the rocker panels just yet, and your rockers will be a bit higher up after the new tires anyway. Have you been hitting the rocker panels? I'd do the gears so that you have good power to the larger tires, and then locker.
danielbuck is online now
post #10 of 79 Old 09-16-2011, 08:08 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
rockers should be the first piece of armor you should buy, end of story. and while you're at it - get something you wont want to replace in a few years
http://shop.savvyoffroad.com/product...6&categoryId=9
My builds:
and
or follow us on
spyder6 is offline
post #11 of 79 Old 09-16-2011, 08:09 AM
Jrob05
How about trying to find a Dana 44 in a junkyard? If you could find one out of a rubicon you'd get a stronger axle, 4.10 gears,an air locker and disc brakes, you would only have to regear the front. I don't know what else you would need for the swap except maybe some brake lines, and parking brake cable and the pump for the locker.
Jrob05 is offline
post #12 of 79 Old 09-16-2011, 08:11 AM
NotURMailman
NotURMailman's Avatar
I would do the re-gear with a gear type LSD in the rear. You can add an Aussie Locker to the front later.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #13 of 79 Old 09-16-2011, 08:20 AM
CT99XJ
right. Cuz Aussies in the rear kill babies.
Rear locker first, as long as you don't have a D35. If you do, spend your money on something that's not a toothpick first, like an 8.8 or D44.
CT99XJ is offline
post #14 of 79 Old 09-16-2011, 08:22 AM
CT99XJ
Yeah, finding that in a JY is gonna be a grand-plus. That's if someone was stupid enough to junk a Rubi without pulling the axles out of it. Good luck finding one.
CT99XJ is offline
post #15 of 79 Old 09-16-2011, 08:51 AM
spyder6
spyder6's Avatar
2010
i dont think that what he meant, considering that the guy has a Dana 35
My builds:
and
or follow us on
spyder6 is offline
gears , locker , rocker guard
locker and gears. baellis1 TJ Wrangler Technical Forum 31 03-13-2011 07:51 AM
need to buy gears and arb locker ClassicRiderhp TJ Wrangler Technical Forum 18 04-28-2010 09:10 AM
4.56 Gears & Ox Locker VnutZ TJ Wrangler Technical Forum 5 08-04-2009 09:38 PM
4.88 gears ox locker ? beerking1 TJ Wrangler Technical Forum 13 01-01-2009 10:35 AM
Gears & Locker - What shall I do? Marshmellow YJ Wrangler Technical Forum 3 07-13-2002 10:00 AM
