Locker/LSD Pros vs Cons - JeepForum.com
post #1 of 22 Old 11-16-2010, 06:05 PM Thread Starter
ajf1994
Ok... I have an '04 TJ, stock axles (D30 & D44) that are both currently completely open. I want to put lockers/LSDs in, but am not sure which is better for my environment. I drive on a lot of snow, slush, and ice covered roads. I don't have the money to afford both, so I was wondering what was the most beneficial for On/Offroad use. I don't know how a lunchbox locker would be in the back, working all the time, so I was thinking maybe a TrueTrac in the back, Aussie up front? Any help & suggestions?
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #2 of 22 Old 11-16-2010, 06:10 PM
fowfiddy
tru trac in rear would be ok in snow, a locker in the front would make it so you couldnt drive safely in 4wd on snow covered roads. arbs are about only way to get traction when you need it and leave them open in snow.
fowfiddy is offline
post #3 of 22 Old 11-16-2010, 06:10 PM
shotgunsmith
I lived in Buffaluv my first 28 years. Always ran (and still do) slipper in back and locker in front. I would rarly use 4wd unless conditions were severe and speeds slow. driving over 25/30 with the front locked can be a little exciting
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline
post #4 of 22 Old 11-16-2010, 06:12 PM Thread Starter
ajf1994
I don't think I would want to drive over 25 in 4WD in snow anyways.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #5 of 22 Old 11-16-2010, 06:18 PM
shotgunsmith
Then your cool
HST
post #6 of 22 Old 11-16-2010, 06:20 PM Thread Starter
ajf1994
So which do you think is a better choice to buy first?
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #7 of 22 Old 11-16-2010, 06:26 PM
shotgunsmith
the locker
HST
post #8 of 22 Old 11-16-2010, 06:27 PM
Tuffjeeper
IMHO Driving with Lockers in the snow is not nearly as big of deal as some make it sound... Even with open diffs you can get the back end to whip around. You just have to be smart about it. If you drive the Jeep like a Jeep and not rally it everywhere you should be fine.
I used to be a fan of selectable lockers until all my buddies at one time or another has had their ARB lockers fail on them for one reason or another (usually electrical reasons). Because of that I went Detroit fore and aft and havent looked back!
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline
post #9 of 22 Old 11-16-2010, 06:46 PM
Kiwi_TJ
TrueTrac
Hi There,
I have a TrueTrac in my rear diff and found that it works really well on slippery surfaces. In previous situations, when I put my foot down, with my open diff, the back would slide around, with the TrueTrac, it is just point and shoot, it seems to just grip and go.
I really like it, and if I was to regear, which means I would need a new carrier in the front, I would replace the open carrier with a TrueTrac.
Most of my Jeepin' is mud/gravel etc, not big wheels in the air stuff, so I find the TrueTrac works well for me.
Hope that helps
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #10 of 22 Old 11-16-2010, 06:47 PM Thread Starter
ajf1994
Helps a lot. Thank you!
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #11 of 22 Old 11-16-2010, 07:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I've never had an ARB fail? Run them in 4 different axles with 4 different ARB's. None of my friends have had a problem either...
Knuckelhead is offline
post #12 of 22 Old 11-16-2010, 07:37 PM
jeepinmichguy_
Ive only seen airline issues, which I would blame on the installer not ARB. I have never seen the locker itself fail.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #13 of 22 Old 11-16-2010, 08:07 PM
J03_TJ
Hate to ask, but driving in 2wd, which would be preferred, an ARB in the back or a Truetrac in the back, for commuting on snowy, icy roads?
J03_TJ is offline
post #14 of 22 Old 11-16-2010, 08:41 PM
sduncan
sduncan's Avatar
I haven't had mine very long, but I went with advice and reviews when I bought my ARBs. I am glad I went with them.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #15 of 22 Old 11-16-2010, 08:47 PM
srlbotanical
I wouldn't trade my locked rear end for a LSD off road. I like to be locked. But, up here in Michigan, it can get a little hairy being locked in slippery road conditions. I won't let my wife drive the jeep on the roads when it's slippery. If snow is your number one concern, then I don't think you can go wrong with a true-trac.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
aussie locker , locker , lsd , tj , true trac
94 yj pros and cons? beachrusso YJ Wrangler Technical Forum 21 11-14-2007 07:20 AM
pros & cons of a v8 axehead TJ Wrangler Technical Forum 18 04-25-2007 09:35 PM
between these two, the pros and cons wrangler2007 TJ Wrangler Technical Forum 22 02-18-2007 05:42 PM
Pros & cons : EZ Locker Bob_Barker YJ Wrangler Technical Forum 5 07-10-2005 05:58 PM
