Locker or Lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Locker or Lift?
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 01-04-2009, 08:47 PM   #1
phxdrumpro
Locker or Lift?
This will be my first purchase for my 01 TJ.
It is stock with 30x9.50 AT's
I am either looking at spending my budgeted $300 on...
Aussie locker for the front
2" Lift
I am pretty happy with the factory clearance and dont plan on running anything larger than 31's. The stock flex disconnected suits me. Stock shocks are a little stiff for my taste.
I am going to lock up the front sooner or later...thought I would do it sooner while I have the money!
Opinions?
phxdrumpro is offline   Reply With Quote
Unread 01-04-2009, 08:50 PM   #2
abeshures
trust me you will want more lol. thats a tough choice though. id go with the lift and better tires if you could. a locker would be useless with crappy tires. keep us updated on what you do and good luck
abeshures is offline   Reply With Quote
Unread 01-04-2009, 08:54 PM   #3
RnEmOvr
Will tow
RnEmOvr's Avatar
save you money and get better tires
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
FBI data shows that 323 murders were committed with rifles of any kind in 2011. In comparison, 496 murders were committed with hammers and clubs, and 1,694 murders were perpetrated with knives.
RnEmOvr is online now   Reply With Quote
Unread 01-04-2009, 08:58 PM   #4
phxdrumpro
I kinda like my tires. Nearly new Coopers...
If I did get new tires, I would get some MT's or XT's...
I just wanted to get the locker done and out of the way considering lifts seem to be a neverending process!
Unread 01-04-2009, 08:59 PM   #5
RnEmOvr
Will tow
RnEmOvr's Avatar
then go locked
Unread 01-04-2009, 09:09 PM   #6
ca-rj
Lock it up. It will make the most impact on your wheeling.
Ryan
2005 Jeep Wrangler Unlimited Rubicon Sahara
OME 2.5" springs | Doetsch Tech DT3000 shocks | 285/75-16 Nitto Terra Grappler AT's | Yaesu FT-7800R | Cobra WX75st | Firestick Antenna | Alpine CDA-9883
ca-rj is offline   Reply With Quote
Unread 01-04-2009, 09:46 PM   #7
CJnaTJ
Lock it. (Spoken by someone who is currently WITHOUT a locker and new 33" KM2's)
Blue 2003 TJ X
4" lift; 33x12.50 KM2s; front LockRight
CJnaTJ is offline   Reply With Quote
Unread 01-04-2009, 09:49 PM   #8
Jeepster83
personally it sounds like a case of igottadosomethingtomyjeepitis. save your money a little while longer to get something really good or a few good things. tax season is just around the corner.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline   Reply With Quote
Unread 01-05-2009, 01:07 AM   #9
97casteeltj
an Aussie Locker is really good
needing a new rig....
97casteeltj is offline   Reply With Quote
Unread 01-05-2009, 01:09 AM   #10
Strizzy
I'd say skip teh locker for now and put the $300 aside to add to a good quality lift.
Wheeling without a locker will teach you how to wheel better by finding correct tire placement and choosing the right line. I feel people depend too much on their lockers.
Learn to wheel without the locker for now and save for a good spring lift and at least 32's (when your 31's wear out).
Strizzy is offline   Reply With Quote
Unread 01-05-2009, 01:18 AM   #11
97casteeltj
how often do you use your lockers?
Unread 01-05-2009, 01:34 AM   #12
Strizzy
My last wheeling trip I turned them on once on a steep muddy rocky incline. Still couldn't get up after about 10 minutes of trying.
It's also much more fun when the lockers aren't being used.
Unread 01-05-2009, 01:38 AM   #13
jumbojeepman
1976 CJ7
I say lift first. Getting the vehicle frame up off the obstacles helps so much.
jumbojeepman is online now   Reply With Quote
Unread 01-05-2009, 01:40 AM   #14
97casteeltj
he said he was happy with factory clearance (which i'm sure he wouldn't mind a bit more) but i'd say get some armor on it, preferably on the underside.
Unread 01-05-2009, 09:30 AM   #15
phxdrumpro
One factor I am looking at is the used parts market.
I trust used lift parts much more than a used locker (I dont know why...just do!).
Guys seem to be upgrading lifts much more frequently than lockers.
I know this leads to "adopting someone else's mistake" but there is some value in learning what works and what doest by experience as well as learning how much lift you need for YOUR style of wheeling.
Not everyone needs 6" of lift and 40's...I know I sure dont.
So I am keeping my eye on used lift springs, etc and trying to find the best deal on a new locker.
I will end up doing both but just trying to find out which one should be first.
