LOCKER ISSUE > Just installed lunchbox locker - problems - JeepForum.com
post #1 of 8 Old 12-26-2006, 08:34 PM Thread Starter
msavard
msavard's Avatar
Just installed an Aussie locker in my D30 up front. Everything seemed to go smoothly... however we're having some pretty big issues now.
After getting it all back together, I took it for a ride. When I engaged 4WD it acted up.
Symptoms:
Wheel jerks left
EXCESSIVE popping when turning
Disengaging takes time after shifting to 2WD (this is probably normal)
There was also some gridinging when I first started testing the gears in the garage... it oculd have been my TCase linkage as it's not dialed in right now but who knows...
Thoughts?
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto 35" Maxxis Bighorns D30/D44 w 4.88 Gears 2.5" OME LJ/XJ lift JKS Trackbars Brown Dog MML 1" BL Warn Engine Skid Aussie Locker (FR) / Rubi Air Locker (REAR) SYE/CV Nth Adj Control Arms Bestop Oversize Tire Carrier PSC Rocker Knockers ORO Swayloc TNT Tube Fenders
msavard is offline
post #2 of 8 Old 12-26-2006, 09:06 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
sounds pretty normal. 4wd on the street sucks with it. I have the lockright in my D 30. It's locked fully now, those are the quirks of it.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 8 Old 12-26-2006, 09:12 PM Thread Starter
msavard
msavard's Avatar
This was pretty much undriveable though.... As soon as 4wd kicked in the steering wheel jerked abruptly to the left and the jeep tried like hell to turn sharply to the left. Noise from the diff didn't sound right... I've ridden in rigs with lunchbox lockers before... there is something wrong.
msavard is offline
post #4 of 8 Old 12-26-2006, 09:29 PM
tcourdin
tcourdin's Avatar
You will not be able to run 4wd like that on dry pavement. It will definately buck, jump, crack, pop and pull all over the place! It espescially wont turn while in 4wd on the pavement!
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline
post #5 of 8 Old 12-26-2006, 10:16 PM
Trebor
no experance here sorry, but did you try it on a slipery lawn or big mud puddle? mabe that will tell you for sure.
Bobby T...Out!!!
Trebor is offline
post #6 of 8 Old 12-26-2006, 10:17 PM
Trebor
just to make sure
Bobby T...Out!!!
Trebor is offline
post #7 of 8 Old 12-26-2006, 10:53 PM
ndvipergtsr
Take it on a gravel or dirt road then try it.
2006 Solar yellow Rubicon Unlimited.
ndvipergtsr is offline
post #8 of 8 Old 12-26-2006, 11:11 PM
UTWeezul
Mine did this too and it's normal. Any kind of pavement sucks in it. Sometimes if it is really dry off road it will still try to pop and pull in different directions. Just the normal quirkyness of an autolocker. Mine doesn't seem to do it as much now that I've used it a few times.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
Lunchbox locker timcfuller TJ Wrangler Technical Forum 2 04-02-2009 05:09 PM
Lunchbox locker jacksonjeeper TJ Wrangler Technical Forum 3 02-16-2009 06:30 AM
lunchbox locker in a D30 troy.j TJ Wrangler Technical Forum 19 01-26-2009 12:12 PM
Lunchbox locker hondacr21 YJ Wrangler Technical Forum 5 05-07-2007 04:02 PM
What is a Lunchbox Locker? JeepinYahoo TJ Wrangler Technical Forum 16 04-03-2006 02:18 PM
