Locker indicator lights question - JeepForum.com
post #1 of 3 Old 07-27-2010, 01:37 PM Thread Starter
Tryer
I just installed the two switch modification to turn my lockers on. The front pump turns on and the indicator light blinks, and then turns on steady when the pump is up to pressure. The rear turns on and the light blinks, but when it is up to pressure the pump quits, but the light still blinks. I can hear the rear pump stop as it comes up to pressure. I hate blinky lights. Any idea where to look first? Doesn't the sensor turn off the pump?
Tryer is offline
post #2 of 3 Old 07-27-2010, 02:06 PM
Noxian
2011 JK Wrangler
The pumps shut off when they sense they have reach the correct pressure (5psi)
The light is controlled by the computer which uses a sensor (electronics switch) in the diff to tell if the locker is locked or unlocked.
If the light blinks than it means your locker isnt locked, malfunction in the locking system, or the sensor in the diff is bad, or the wirring/computer is bad.
I had a sensor go bad in mine and the locker was working, I could hear the pumps shut off and I could tell the locker was working as I tested it offroad. But the locker light would just keep blinking, Unfortunately to replace the sensor in the diff you have to pull the carrier which can be alot of labor.
Hope that helps.
Noxian is offline
post #3 of 3 Old 07-27-2010, 02:06 PM
kuebelwagen
I did the dual switch mod and both My lights flash continuously while the lockers are engaded, no help, same problem.
In love with, Suki.
Pain is weakness leaving the body.
2004 Rubicon
1995 Cherokee
kuebelwagen is offline
locker indicator light , rubicon
Indicator Lights After Lift TGuiles JK Wrangler Technical Forum 9 07-20-2010 04:42 PM
4wd indicator lights andrewnovell TJ Wrangler Technical Forum 4 11-27-2009 09:29 PM
question about rubicon indicator lights nowickyj Wrangler General Discussion 0 10-02-2008 06:39 PM
False locker indicator{rubicon} OffCamberTJ TJ Wrangler Technical Forum 6 01-26-2007 08:40 PM
02 TJ 4WD indicator lights domano 68 TJ Wrangler Technical Forum 13 03-06-2006 09:17 PM
