Locker bypass? - JeepForum.com
post #1 of 13 Old 07-11-2009, 04:12 AM Thread Starter
djleathal7
2011 JK Wrangler
Locker bypass?
Was wondering if anyone has tried the locker bypass on a 2006 Rubicon? Got the mod from RockCrawler.com. Specifically the one to be able to lock in 4 low or 4 high at any speed.
djleathal7 is offline
post #2 of 13 Old 07-11-2009, 05:37 AM
jeep06
jeep06's Avatar
2015 KL Cherokee
Yep,, here is one thread about it... many other I am sure. I did it to my '05 and it works great,,, if you think you need it that is.
http://www.jeepforum.com/forum/showt...ubi+locker+mod
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #3 of 13 Old 07-11-2009, 06:22 AM
binski
binski's Avatar
I did mine almost 2 years ago ... no regrets.
binski
Binski
Christian Jeep Club Member 257
Red Jeep Club Member 245
binski is offline
post #4 of 13 Old 07-11-2009, 03:54 PM
mrfast
I just got done doing this modification on my 06 about 15 mins. ago, using the above link for directions It's a easy mod.
mrfast is offline
post #5 of 13 Old 07-11-2009, 05:06 PM
xulcuz
Just did mine today too... I used the write up from stu's offroad http://www.stu-offroad.com/electrical/rubi1/rubi1-1.htm very easy to do! Took about fifteen minutes to complete.
-2003 Rubicon 4.0L with 5 spd- RE 3.5 SF lift, OME shocks, 33X12.50X15 Good Year MTR's, Mickey Thompson Classic Lock II's, Rokmen Mercinary front bumper, warn winch, Alloy USA axle shafts, Warn Rear bumper with tire carrier, Poison Spyder Customs Rocker Gaurds, Rubicon Express Chromoly Tie Rod, Rubicon Express steering stabilizer
xulcuz is offline
post #6 of 13 Old 07-11-2009, 05:11 PM
Xlr8n
1967 JK Wrangler
While the jumper wire method is quick and easy and works fine, I highly recommend the method of putting a safety switch in the circuit.
Xlr8n is offline
post #7 of 13 Old 07-12-2009, 05:27 AM Thread Starter
djleathal7
2011 JK Wrangler
Switch for locker mod
Would this be the correct wiring for the mod to be able to activate in 4 low and 4 high at any speed with a safety switch? Connecting 4 & 5 together?
post #8 of 13 Old 07-12-2009, 06:22 AM
mrfast
Yes, I believe that would be the correct way to wire it for lockers at any speed.
But I kinda like the idea of being of the safe side and not being able to kick in the lockers at over 10 mph and they kicking out at 45 mph.
I also wired mine with the switch.
mrfast is offline
post #9 of 13 Old 07-12-2009, 07:18 AM Thread Starter
djleathal7
2011 JK Wrangler
So tell me something! When I turn the "safety" toggle to the on position do I still need to push the factory installed toggle to engage the lockers. Also the diagram on rockcrawler.com shows the diagram with no switch for any t/c position at any speed. I pasted the switch in myself. Is this the same wiring as you used? Thanx in advance djleathal7.
post #10 of 13 Old 07-12-2009, 10:53 AM
RogueSpear2023
Yes you still need to hit the hit the locker switch to engage the lockers.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #11 of 13 Old 07-12-2009, 11:04 AM
Vindex_Injuriae
Consider the safety switch if anybody else drives the Jeep - the idea of my fiancee hitting the lock switch at highway speeds makes my credit card cringe....
"Surprise, Speed, and Violence of Action"
05 Rubicon, 6spd, soft top, 265/75/16 Goodyear Authority's
96 K2500, Dual Ranchands & Warn M12000
08 VW Passat Komfort
00 HD Dyna Super Glide FXDX
AU
Vindex_Injuriae is offline
post #12 of 13 Old 07-12-2009, 12:58 PM
mcg311TJ
Look down....
I got both F/R sperate... love it
mcg311TJ is offline
post #13 of 13 Old 07-12-2009, 02:11 PM
ElJaynocibuR
Has anyone ever installed a 2nd OEM locker switch and wired them so you could have a seperate switch for the front and rear lockers?
I think it would be pretty sweet if you could have independent control over both axles and have the OEM switches to make it look like it came from the factory
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
JK locker Bypass zweasel JK Wrangler Technical Forum 5 11-07-2010 02:32 PM
Locker Bypass Ranger659 TJ Wrangler Technical Forum 3 03-21-2009 07:58 PM
Rubicon locker bypass ? steveazoni TJ Wrangler Technical Forum 4 02-09-2009 01:09 PM
Locker relay bypass Poor Boy JK Wrangler Technical Forum 2 05-05-2008 07:20 AM
locker bypass switch WarrenNJ TJ Wrangler Technical Forum 8 04-12-2006 08:29 PM
