Locked my keys in my jeep - JeepForum.com
post #1 of 47 Old 11-10-2010, 04:26 PM Thread Starter
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Hard top
Full doors windows all the way up.
Anyone have any easy way to get into it without breaking anything? The rear glass doesn't seem very tight like I could amount pry it out but I really don't want to break anything on it if I can avoid it.
Arcticcat843 is offline
post #2 of 47 Old 11-10-2010, 04:41 PM
QuickSilverCon
call a locksmith?
Originally Posted by timberwolf0122 View Post
I think you are confusing the right to free speech with the right to be a **** bag, only one is protected by the constitution.
QuickSilverCon is offline
post #3 of 47 Old 11-10-2010, 04:42 PM
craigbru
craigbru's Avatar
2007 WK
Remove your doors?
Jeep-Core
craigbru is offline
post #4 of 47 Old 11-10-2010, 04:46 PM
BombThreat
How would you do that? If your thinking about unbolting the hinges from the door, just call a locksmith. This bolts will either strip or the very least you will be chipping the he LL out of your paint.
When I cant go around it, run it over!
BombThreat is offline
post #5 of 47 Old 11-10-2010, 04:52 PM
beartree
Give your Jeep dealer your VIN & get a new key.
beartree is offline
post #6 of 47 Old 11-10-2010, 04:54 PM
yellowjesus
Time to keep a spare in the engine bay...I locked mine in once but i thankfully had the trunk unlocked so i could crawl through...Not sure how to get in...try the back glass
yellowjesus is offline
post #7 of 47 Old 11-10-2010, 04:55 PM Thread Starter
Arcticcat843
dakuda is a god
1980 CJ5
Yeah I'm pretty sure the hidges won't unbolt easy
post #8 of 47 Old 11-10-2010, 04:58 PM Thread Starter
Arcticcat843
dakuda is a god
1980 CJ5
I need to drive it 200 miles home tonight, I'm in class now but I have a break pretty soon. I think I'm going to try to pry the back glass open
post #9 of 47 Old 11-10-2010, 04:58 PM
justanotherjpr
You've basically got three choices.
1. Unlock the door with a coat hanger. Probably scratch the paint a little bit but should be OK if you're careful.
2. Mess around with the hinges trying to unbolt them, then figure out that it's still attached at the striker and you'll probably not get very far.
3. Call a lock smith and pay the $40 for a lock out service.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #10 of 47 Old 11-10-2010, 05:00 PM
Martinsc
Im pretty sure you can pry open the back window.
My Build-
Martinsc is offline
post #11 of 47 Old 11-10-2010, 05:02 PM
craigbru
craigbru's Avatar
2007 WK
You don't need to remove the hinges, only the single bolt on the bottom of each hinge. Just like when you remove your doors... Even if it's still attached at the striker, you may be able to reach in enough to unlock it.
Jeep-Core
craigbru is offline
post #12 of 47 Old 11-10-2010, 05:03 PM
tjsaharaWHITE
remove the rubber on drivers window and hit the connectting rod of lock with measuring scale it will pop open
tjsaharaWHITE is offline
post #13 of 47 Old 11-10-2010, 05:20 PM
Gamble27
Word of advice for the future, keep a spare key in your wallet.
Gamble27 is offline
post #14 of 47 Old 11-10-2010, 05:25 PM
carlson
carlson's Avatar
Yes, it's pretty easy.
Read my post on this thread....
http://www.jeepforum.com/forum/f9/do...nside-1076616/
2012 Black Rubicon Unlimited
2.5 Max Travel Rock Krawler Lift
Bushwacker Flat Fenders
35" Goodyear Duratracs
carlson is offline
post #15 of 47 Old 11-10-2010, 05:28 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Word for the unwise...get AAA card and keep a spare key in your wallet!
GOLENJEEPTJ is offline
keys locked in car bluetj04 JK Wrangler Technical Forum 32 12-08-2010 10:46 AM
help, locked my keys viperbluelx TJ Wrangler Technical Forum 28 09-03-2010 07:25 PM
Need Help A.S.A.P (Keys locked inside Tj) John_Wayne Wrangler General Discussion 12 01-10-2010 05:57 PM
HELP!! locked keys in Jeep while running sheps21 TJ Wrangler Technical Forum 25 01-20-2007 10:23 AM
Keys locked in mud4blud TJ Wrangler Technical Forum 42 07-21-2005 10:23 PM
