Lock Ring Pliers/ Snap Ring Pliers for SYE
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
ive been searching high and low all morning for a pair of lock ring pliers and snap pliers that have been effective and have been used on SYE. As I searched through posts it seems that everyone makes it a point that they should have a good set of these when doing this install but no one points out a tried and true set. Links would be great. Thanks in advance
#2 |
Here is a link to the lock ring pliers I used. They worked great. There was no need for snap ring pliers.
http://www.sears.com/sr/javasr/product.do?BV_SessionID=@@@@0261447061.1134926538@ @@@&BV_EngineID=ccicaddghliiehecegecegjdghldgfi.0& pid=00947386000&vertical=TOOL&ihtoken=1
1998 XJ, RE 3.5" Lift |
#3 | |
Brake Wizard
You need a pair with fixed tips, not interchangeable. They need to open a minimum of 2" and have decent length handles for the needed leverage. Cross hatching on the tips to prevent slippage is a plus. I do know that I mentioned in USMoronLJ's SYE thread that the Craftsman set didn't open wide enough for the big lock ring encountered in a SYE install and that info was probably more important that the rest of the shenanigans involved. Further, do not buy any snap ring pliers with interchangeable tips. All they do it get your hopes up with their fanciness and dash them with abysmal performance. Crescent makes some convertible pairs that go from internal to external with a simple swap around of the pivot point, Knipex makes awesome stuff, as do many others. Don't buy cheap crap and you'll be just fine.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#4 | |
http://www.offroadoverstock.com/store.cfm?Product_ID=52231&page=details.cfm&cartac tion=none&thisrow=14&action=list&criteria=30&start row=11&mystartrow=11&maxrows=10&cat=10&man=&stay=& afid=&searchcat_id=&itemprice=&searchfield=&search man_id=&boolean=OR&var1=&var2=&var3=&return_produc t_id=&makeid=&modelid=&modelyear=
1998 XJ, RE 3.5" Lift Last edited by jaburk; 11-22-2007 at 09:18 PM.. |
#5 |
Do it right or not at all
![]() Join Date: Jan 2003
I bought my snap-ring pliers on one of those roving tool trucks (MAC, Snap-on, Matco etc.) that sell directly to mechanics. I never found any that opened widely enough in a retail store.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#6 | |
This is the set I used and they worked great. They lock when the ring is open so so don't have to hold it open while trying to remove. Good luck. |
#7 | |
#8 | |
Brake Wizard
Not every SYE replaces the tailcone and those require the removal of the bearing out of the stock tailcone which is held in with a what?
#9 | |
#10 | |
#11 |
Moab dreamin'
This is a perfectly timed post for me as I've got the SYE sitting in the garage and am in the market for some snap/lock ring pliers to intsall this AA kit. Any direct links to good pliers appreciated.
I was looking at the same napa ones linked yesterday, so you think those are too much?
'98 TJ (see profile) '88 YJ with 4.0/AW4 swap & CJ front end '97 XJ 4.0/aw4/3.5" lift/33x10.5 BFG ATs '80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0) |
#12 |
Here are some much cheaper.
http://order.harborfreight.com/EasyAsk/harborfreight/results.jsp?ts=Sun%20Dec%2018%2011:56:37%20PST%202 005
2000 Sport. |
#13 | |
#14 | |
#15 |
Moab dreamin'
It does have the bearings installed, so thats nice to know I won't need the snap ring pliers. I'll see if the local sears has those. Thanks.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
