lock right - JeepForum.com
post #1 of 4 Old 05-11-2013, 07:51 PM Thread Starter
snookhansel
lock right
Do I need to install the washers that were behind my spide gears behind my lock right.
snookhansel is offline
post #2 of 4 Old 05-11-2013, 08:02 PM Thread Starter
snookhansel
I was gonna upload a picv
But for some reason jf is not happy. The washers I'm speaking of are behind the splined spider gears for the driveshaft.
post #3 of 4 Old 05-11-2013, 08:33 PM
Garza
You re-use the thrust washers, but not the conical "shims" behind the actual spider gears. For example in this pic you would re-use the 2 upper washers, NOT the lower ones. Hope that helps.
Garza is offline
post #4 of 4 Old 05-11-2013, 09:54 PM Thread Starter
snookhansel
10-4. I thought so and have disassembled and installed those two washers. Lock rights instructions are fuzzy and kinda hard to follow. The pics really suck.
I see after putting the locker together it fairly simple. They still should consider ky boys have a snoot or two of bourbon while doing these kind of projects.
