-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   lock right (http://www.jeepforum.com/forum/f9/lock-right-1522126/)
snookhansel 05-11-2013 08:51 PM
lock right
Do I need to install the washers that were behind my spide gears behind my lock right.
snookhansel 05-11-2013 09:02 PM
I was gonna upload a picv
But for some reason jf is not happy. The washers I'm speaking of are behind the splined spider gears for the driveshaft.
Garza 05-11-2013 09:33 PM
263 Attachment(s)
You re-use the thrust washers, but not the conical "shims" behind the actual spider gears. For example in this pic you would re-use the 2 upper washers, NOT the lower ones. Hope that helps.
http://www.alljeep.com/oscommerce/images/IPK.jpg
snookhansel 05-11-2013 10:54 PM
10-4. I thought so and have disassembled and installed those two washers. Lock rights instructions are fuzzy and kinda hard to follow. The pics really suck.
I see after putting the locker together it fairly simple. They still should consider ky boys have a snoot or two of bourbon while doing these kind of projects.
The time now is 12:26 PM.
