#1 | |
Lock front or rear?
Debate with some friends going here. If you were short on money and were going to install a locker in an off roader, ( not DD ). One says front is the only way to go, Other says rear. Whats your opinion and why?
#2 |
I did the front only because I got a smoking deal on a ARB. It is hard to say for me tho. I know there is good and bad for both, but I like the front. If I can't get on an obsticle, hit the locker and can usually crawl up on it. Rear locked and you are still trying to push your "brick" up onto the rocks or other obsticle. Front is the way to go for my $$$.
#3 |
I locked the rear, with an LSD in the front. The consensus I saw on the forums here before I did it was that 90+ percent of the time a rear locker will get you through a tough situation due to the fact that when climbing, the vast majority of the weight of the Jeep is shifted to the rear axle, giving it better potential traction than the "lite" front. So far, being locked in the rear has worked great for me. My Jeep sees some snow driving duty, hence the LSD in the front, otherwise I would have put an Ox on both ends, not just the rear.
Chris B. Evergreen, Colorado 2000 Sport - details in profile. Last edited by quattrogato; 11-20-2008 at 01:32 PM.. Reason: Clarification |
#4 |
Go with a front if you want a lunchbox and go rear if you want a selectible
build it, wheel it, break it, repeat 1983 CJ 7 (traded for TJ) 1992 YJ Renegade (sold) 1999 XJ Classic (daily driver) 1997 TJ Sport (building) |
#5 |
I use the rear more than the front. I like having a selectable up front so I can turn it off to steer when needed.
#6 |
I'd go with a locker in the rear because of the fact that climbing you will get better traction
Other Vehicles: 07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs 08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers |
#7 |
it also depends on your axles.
if you have a 30/35 combo i would say lock the front up with an Aussie; but if you have a 30/44 setup or better i would lock the rear up with a selectable, but if money is tight go for some sort of auto locker, but not the Aussie in the rear they tend to act up in the rear. -John
needing a new rig.... |
#8 |
Dont waist money on a LSD. Pay money for a rear locker and through a lock right in the front.
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners. Vote for TJOFTY! http://www.jeepforum.com/forum/f9/tj-year-contest-2010-vote-now-contest-has-started-1140918/index9.html |
#9 |
Wahoowa
Heck if it's not a DD like you say, just throw some lunchbox lockers for cheap in the front and rear. But if you had to choose one, I would definitely lock the rear first. When the Jeep climbs up an obstacle most the weight transfers to the rear and is where a lot of the traction is needed to pull you over. Regardless if you lock one or the other you will notice a huge difference than open front and rear.
White 01 TJ Sport 4.0 NV3550 |
#10 | |
Owner of REPOST™
if i was told $350, i would put an aussie in the front and a mini spool in the back (as long as it was not a D35).
<>< Member #35 Red Jeep Club Member #337 What you are is God's gift to you... What you make of yourself is your gift to God. Make a change. Be different. |
#11 | |
Some Call me RockDog
ebay 52.99 but doesn't work with posi rear. Heck weld the spiders.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#12 |
It is a road worthy TJ it takes me to work and back each day, 5 blocks. On the weekend's it does a hundred or less miles off road. Im not concerned with the on road limitations of the front locker. The weather conditions in my area may require I park the Jeep for a couple weeks if snow gets bad. I am concerned only with the off road performance. D30 front 8.8 rear. want to spend Less than $400.
#13 | |
Owner of REPOST™
is the rear limited slip?
#14 | ||
#15 | ||
![]() Since you don't care about onroad manners, For best offroad performance lock the rear with what you can afford. The rear benefits more as some have stated, also locking the front with anything but a selectable affects turning on tight trails when in 4wd. ![]()
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
