location of middle body mount bolts inside tub - JeepForum.com
post #1 of 5 Old 09-09-2013, 04:44 AM Thread Starter
TJJeepJosh
I know there's a thread on this for the yj's ( http://www.jeepforum.com/forum/f12/b...-w-pix-705291/) but I can't seem to find one with picture or a very good description for TJ's.
Bought some trail gear rock sliders recently but when I went to loosen the body mounts, the two further back on each side between wheel wells, all they do is spin. Since I don't have the skills or tools to cut up the floor or remove the tub to remove I was thinking I could drill a 1 inch hole above each bolt to get at them and then put a drain plug in place of each hole.
My question is where do I drill in the floor from above? since it will only be a 1 inch or so hole it will have to be directly above the bolt.
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 5 Old 09-09-2013, 10:28 AM Thread Starter
TJJeepJosh
anyone?
post #3 of 5 Old 09-09-2013, 10:40 AM
biffgnar
biffgnar's Avatar
Are you looking to do something like this: http://www.jeepforum.com/forum/f9/fi...50/index2.html. PM Unlimited04 with questions. He will be helpful about what he did.
Romney in 2020!
biffgnar is online now
post #4 of 5 Old 09-09-2013, 11:28 AM
AllTerrainJK
The rearward mount in the torque box can be seen inside the tub right next to the seatbelt retractor. It is a round bulge in the floor pan which is a relief for the bolt. The middle one is a pita as it's just forward the seat or under it. I need to look at my jeep to be sure on that one. I will check after work.
Roads? Where we're going we don't need roads!
AllTerrainJK is offline
post #5 of 5 Old 09-09-2013, 08:08 PM Thread Starter
TJJeepJosh
Similar but to a different bolt and without a welder since I don't have one. That's why I thought drain plugs might work.
I'll see what he can help with.
Try looking at it closely before it got too dark today. Rear seems like it will be the easier one to get to with that bulge you're referring too. Middle one again as you said looks like it will be a pain to get at with the dip from the seat to floor pan almost right above it. Have to look more thoroughly when I get some spare time.
body mount bolts , help needed , opinions wanted , spinning
