lj and SYE question - JeepForum.com
post #1 of 11 Old 08-20-2013, 12:09 AM Thread Starter
danmauro
lj and SYE question
So I've had the 3 inch lift on my 05 Lj a little over 4 years now and it is way past time for a change (my front springs are sagging and it makes me sad). I am thinking of dropping some dough and moving up to a 4.5" lift (something with johnny joints all out the wazoo). The question I have come across and can't seem to find a definitive answer to is do I need an SYE with the longer rear drive shaft of the Lj? I do a fair amount of moderate (not a subjective statement at all...) off roading and while the 3 inches of lift have served me fine so far...my cousin just put 4 inches on his 09 Wrangler and now it's taller than mine!
Also if you'll all forgive my ignorance...
The slip yolk itself slides in and out of the Xcase with rear axle movement. Does having the slip yolk eliminator limit the movement of your rear axle because the rear drive line no longer has the ability to "make itself longer"? Is the replacement rear axle kind of one size fits all, or do you have to order based specifically to fit the lift you are doing?
Also I have heard a lot about how an SYE and new rear drive shaft is the way to go simply because it is stronger, and odds are that no matter what I will eventually be putting one on. But I am not exactly made of money so if I get the lift now, I need to save up for the SE later and vice versa which is how the whole "do I really need it?" came up.
danmauro is offline
post #2 of 11 Old 08-20-2013, 12:24 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Is your LJ a Rubicon?...
DANMAURO'S JEEP
Year & Model
Engine
4.0L
Front Axle
dana 44
Rear Axle
dana 44
Gear Ratio
4:10
Knuckelhead is offline
post #3 of 11 Old 08-20-2013, 12:27 AM
jaspepp
The SYE simply changes the t-case output to a fixed yoke, which requires a different drive shaft. This allows for a steeper/more proper pinion angle. But if you don't get adjustable control arms you can't adjust you r pinion angle. It turns into a snowball effect real quick at that point. If you don't have vibrations I wouldn't worry too much about it. An LJ is great rig!!!
"Idaho sucks!!!! Tell California"
jaspepp is offline
post #4 of 11 Old 08-20-2013, 12:35 AM Thread Starter
danmauro
My Lj is not a Rubicon. It came with the 44's stock and I upgraded the gearing.
danmauro is offline
post #5 of 11 Old 08-20-2013, 12:37 AM
sjones26573
So did you do an axle and gear swap?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #6 of 11 Old 08-20-2013, 12:41 AM
Knuckelhead
AFSOC Retired
Non Rubicon LJ's don't come stock with front D44 axles, they come with LPd30's...
post #7 of 11 Old 08-20-2013, 12:49 AM Thread Starter
danmauro
I don't know what to tell you. I have a dana 44 up front be it from the previous owner or however. But can we focus on the rear end of my jeep as that's what I'm asking about?
danmauro is offline
post #8 of 11 Old 08-20-2013, 01:01 AM
Knuckelhead
AFSOC Retired
If you're going to 4.5" suspension lift, I would think that an SYE, DC driveshaft and adjustable control arms would be a good idea.
The DC driveshaft/SYE would replace the slip yoke and move the slip yoke function to the middle of the driveshaft...
post #9 of 11 Old 08-20-2013, 10:00 AM
joe_jeep
4.5" is pushing it on height for an lj without a sye and cvds. im sure its been done, but u might get some vibration.
you should do an sye!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #10 of 11 Old 08-20-2013, 11:04 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i think there are some links about this in my sig.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 11 Old 08-20-2013, 09:44 PM Thread Starter
danmauro
Thanks, your sig answered pretty much all of my questions.
danmauro is offline
lift , lj , sye
