LJ Slip Yoke...how far can it slip..oops! - JeepForum.com
post #1 of 13 Old 08-03-2010, 05:24 PM Thread Starter
semprfimac
How far can my LJ's slip yoke "slip" / how bad a situation, before I'm on my back and try'in to reconnect it ? or worse.....
I know i need an SYE & CV shaft but until the funding is available I still need to wheel,
OoRah, Get Some !
semprfimac is offline
post #2 of 13 Old 08-03-2010, 06:14 PM
AFjeepMan
There are many people out there with 4" lifts and still running the slip yoke. I have a 3.25" lift and never upgraded to a slip yoke and never plan on it. I have plenty of room let and have maxed out my rear articulation without any issues. Do you have a t-case drop?
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 13 Old 08-03-2010, 06:24 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I've had several 4" lifts and never got a SYE or had any problems.
TheBoogieman is offline
post #4 of 13 Old 08-03-2010, 07:45 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
And that's why I've found rear drive shafts with broken rear U joints on the trail. No Jeep, just the DS...
Knuckelhead is offline
post #5 of 13 Old 08-03-2010, 08:05 PM
AFjeepMan
if the rear u-joint breaks as in shears into pieces then the rear driveshaft can fall out if it's not connected to the rear axle, but there are many 1000's of jeepers running the slip yoke with 3.5-4" of lift with absolutely no problems with the yoke slipping off.
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #6 of 13 Old 08-03-2010, 08:24 PM
Terrain Twister
Anyone running one of the EBay setups?
SLIP YOKE ELIMINATOR KIT PACKAGE SYE JEEP CV DRIVESHAFT: eBay Motors (item 320419836868 end time Aug-28-10 22:58:53 PDT)
At that point where it's too much to list!
Terrain Twister is offline
post #7 of 13 Old 08-03-2010, 08:31 PM
Knuckelhead
AFSOC Retired
When the slip yoke falls out, the drive shaft drops causing the rear U joint to fail. I've seen that many times. But, you have to go off road to experience that...
post #8 of 13 Old 08-03-2010, 11:18 PM Thread Starter
semprfimac
Sounds like a mixed bag...some do..some don't,
thanks Knuckelhead
OoRah, Get Some !
post #9 of 13 Old 08-03-2010, 11:22 PM
JLITTY
1946 CJ2A
Cheap insurance to just get the sye. Would suck to be in the middle of nowhere and find out the hard way.
JLITTY is offline
post #10 of 13 Old 08-04-2010, 09:01 AM
bairy
I had a 4" lift with proper wheelbase on clayton long arms...thought i was fine...
At some point I managed to ever so slightly twist the spines on the output shaft probably because there was a lack of engagement at droop. The vibrations the DS can make when there is a locked up slip yoke is freakishly scary. Had to sledge hammer off the driveshaft from the output shaft and drove home 500 miles on the front DS. ...then came a new SYE.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #11 of 13 Old 08-04-2010, 10:17 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2...i've managed to max my LJ's slip yoke out on 2.5" of lift with a tummy tuck. I could almost pull the shaft off with the shocks out and the axle at full droop. I finally installed a DC shaft this past weekend.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 13 Old 08-04-2010, 06:09 PM
Knuckelhead
AFSOC Retired
Experience speaks the truth for others in the learning stage.
Thanks for the input guys...
post #13 of 13 Old 08-04-2010, 08:54 PM Thread Starter
semprfimac
okay, SYE & CV shaft back to the top of the list....thanks guys
OoRah, Get Some !
slip , slip yoke
how much slip does my yoke need mikeg281 YJ Wrangler Technical Forum 1 04-24-2010 10:28 AM
Exploded my slip yoke housing and pinion yoke. durangoyj YJ Wrangler Technical Forum 53 01-12-2009 02:58 AM
old slip yoke rubiwannabe TJ Wrangler Technical Forum 4 06-30-2008 04:30 PM
Slip yoke JpnFirefighter YJ Wrangler Technical Forum 8 12-23-2006 03:05 PM
Slip Yoke/SYE/ETC ETC jeephreak TJ Wrangler Technical Forum 13 08-18-2005 09:49 PM
