LJ / Rubicon U-Joints - JeepForum.com
 4Likes
post #1 of 52 Old 06-02-2015, 08:00 PM Thread Starter
e1harris
I have a 2005 Jeep Rubicon Unlimited (LJ Rubicon)... I'm replacing all of my U-Joints...
According to Jerry Bransford, Spicer & Denny's... The Spicer NON-Greasable U-Joints "should be"...
Front Driveshaft @ Pinion: 5-793x
Front Driveshaft @ CV: 5-1330x (edit: 5-790x is now obsolete)
Front Driveshaft @ T-Case: 5-1330x (edit: 5-790x is now obsolete)
CV Centering Yoke: 211996X
LJ Rubicon w/ Rear Driveshaft #585AA @ T-Case: 5-1330x
LJ Rubicon w/ Rear Driveshaft #585AA @ Pinion: 5-1330x
Spicer's site is out of date. They incorrectly show the "Obsolete" 5-790x for the Front DS @ CV & T-Case.
Denny's lists a pair of Spicer 5-1330x U-Joints as the correct joints for the Front DS @ CV & T-Case.
Can anyone "first hand" confirm this? I've read so many conflicting reports on the Rear Driveshaft U-Joints when it comes specifically to the Unlimited Rubicon LJ.....
e1harris is offline
post #2 of 52 Old 06-03-2015, 01:22 AM
mukluk
For the LJ Rubicon with stock driveline, the correct joints for both ends of the rear driveshaft are 5-790x (which are obsolete, replaced by the 5-1330x). Front DS and axle joints you have listed are correct.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 52 Old 06-03-2015, 06:27 AM
Tonellin
Mukluk is correct. When did jerry post that information? I'm guessing it's a couple years old because until recently there was a ton of confusion with the LJ rear DS ujoints even if you called Spicer themselves.
http://www.rubiconownersforum.com/fo...r-u-joint.html
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #4 of 52 Old 06-03-2015, 07:51 AM
YEAHTOM
Saved! I will need this information one day, Thanks
YEAHTOM is offline
post #5 of 52 Old 06-03-2015, 09:47 AM Thread Starter
e1harris
Deleted for Clarity.
e1harris is offline
post #6 of 52 Old 06-03-2015, 10:08 AM
Tonellin
That is not correct...where did you get that info?
06 LJ Rubicon
Tonellin is offline
post #7 of 52 Old 06-03-2015, 10:14 AM Thread Starter
e1harris
Originally Posted by mukluk View Post
...the correct joints for both ends of the rear driveshaft are 5-790x (which are obsolete, replaced by the 5-1330x)...
Muchas gracias! That makes so much sense now. I spent way too long scratching my head trying to figure that out.
e1harris is offline
post #8 of 52 Old 06-03-2015, 10:16 AM Thread Starter
e1harris
My references were sited above in the 1st post. I referenced Jerry (circa 2013), Spicer's website and Denny's.
Even embedded the links.
I can however "not" confirm the TJ Rubicon Info... so I will remove it as I have a Rubi LJ.
e1harris is offline
post #9 of 52 Old 06-03-2015, 10:18 AM
Tonellin
Oops sorry didn't realize you were the OP when you posted that second chart. This has caused a lot of headaches for many different people just because there is so much contradictory info out there
06 LJ Rubicon
Tonellin is offline
post #10 of 52 Old 06-03-2015, 10:35 AM Thread Starter
e1harris
Updated my above posts as to not mislead anyone.
e1harris is offline
post #11 of 52 Old 06-03-2015, 03:34 PM Thread Starter
e1harris
Yeah, it was from Jerry about 2 years ago.
I've read that forum, but man... it's the only source I've found that says Spicer 5-1330x's for the rear instead of the 1310's... Does he have some sort of factory whoopsie going on for his rear driveshaft..?
I'd assume it'd be all over the Forum / Internet by now if every single dude who owns a Rubicon LJ went to go change out his rear U-Joints and realized that he didn't order the right ones.....
e1harris is offline
post #12 of 52 Old 06-03-2015, 07:16 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There has been a lot of confusion on the right Rubicon driveshaft u-joints since they changed between 2003 and 2004. I am no longer able to provide the correct part numbers for the Rubicon since a computer crash a few years ago wiped that information out. I've been as confused as anyone since then. My 2004 Rubicon doesn't run stock size driveshaft u-joints so I can't even look at my spares to know what a stock Rubicon runs.
Jerry Bransford is online now
post #13 of 52 Old 06-15-2015, 05:50 AM
mclaggan123
jeepaholic
mclaggan123's Avatar
06 lj rubi. im so confused on the ujoint sizes. all the diagrams ive seen show only two ujoints in the rear drive shaft, mine has 3. im trying to replace all my ujoints so i need to know how many of each size to order and what sizes go where. like ive said ive seen a few different diagrams that show different sizes.
2006 Rubicon unlimited, silver. 5.5" long arm lift. 35" BFG KM2's on 15" black steelies. skidrow steering skid and radiator skid . LOD rear bumper with tire carrier. Flowmaster 44 exhaust. .CB with tuffy Overhead storage . Offroad lights in bumpers front and rear plus 2 more on the winch hoop.
mclaggan123 is offline
post #14 of 52 Old 06-15-2015, 06:28 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Stock rear driveshaft does only have 2 u-joints.
You have something that is not stock.
Wheelin98TJ is offline
post #15 of 52 Old 06-15-2015, 06:33 AM
Tonellin
x2
Factory LJR on the left, carolina DC on the right
06 LJ Rubicon
Tonellin is offline
