LJ Long Arm Articulation Test Results. (Pictures) - JeepForum.com
post #1 of 28 Old 06-21-2010, 05:44 PM Thread Starter
DocMojave
I asked the guys at T and J to put my Jeep on their ramp to see exactly what kind of articulation I was getting. I wish they would have taken a couple from the back of the ramp but I'm pretty happy with the results.
Never Mistake Kindness for Weakness. What is desired in a man is kindness, And a poor man is better than a liar.
DocMojave is offline
post #2 of 28 Old 06-21-2010, 05:48 PM
justanotherjpr
Great looking LJ!
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 28 Old 06-21-2010, 06:48 PM Thread Starter
DocMojave
Is there anything I could do to get more articulation or travel?
post #4 of 28 Old 06-21-2010, 06:53 PM
Bennettj13
There always is.
Outboard shocks/ raise upper shock mounting locations for starts.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #5 of 28 Old 06-21-2010, 07:07 PM
lumpster
lumpster's Avatar
looks like shocks are your limiting factor, might be track bars or radius arms too.
lumpster is offline
post #6 of 28 Old 06-21-2010, 07:49 PM Thread Starter
DocMojave
Where do I start?
post #7 of 28 Old 06-21-2010, 07:58 PM
lumpster
lumpster's Avatar
Where do I start?
disconnect shocks, run it up the ramp again, see if that gets you as far as your comfortable with
lumpster is offline
post #8 of 28 Old 06-21-2010, 08:40 PM
emev0l
If you move your shock mounts on your frame higher you can run longer shocks and have more up and down travel.
You can triangulate your rear uppers and lose your rear track bar.
You can get rid of your stock front fenders and run some sort of highline fenders, either tube or something like a AEV highline kit.
If you search those 3 things on this forum you will have a ton of reading.
Just know that there's a lot of cutting and welding involved.
You only want as much flex as you can use, so going past the point where your coil springs become unseated is worthless.
I would search the forum for someone that has your exact lift that has made some of the modifications that I mentioned and ask them a few questions. Do some searches in the build threads, there's some amazing jeeps in there.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #9 of 28 Old 06-21-2010, 08:57 PM
mcg311TJ
A BL and triming those flares will let your SL fully flex out ( or at least flex more then that ). I did that on my jeep and it gave me some more flex.
mcg311TJ is offline
post #10 of 28 Old 06-21-2010, 09:06 PM
cheapjeep06
His tires are tucked up inside the flares so he shouldn't need to trim them... unless there is a way to trim them up underneath where they mount to the fender. My front flares have bumps in them from my tires hitting them before my BL.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #11 of 28 Old 06-21-2010, 09:09 PM
justanotherjpr
I think you're really at about the limit of useable flex. Much more down travel and it's really not going to get you a lot. It really looks great... Can we get some shots of it in action?
post #12 of 28 Old 06-21-2010, 09:30 PM
mcg311TJ
There's about a 1/2 inch of plastic in the wheell well that can be trimmed and the BL would help lift that up even further...
mcg311TJ is offline
post #13 of 28 Old 06-21-2010, 09:31 PM Thread Starter
DocMojave
Coming very soon. Actually for my purposes I think what Ive got is all Ill need but "nothings exceeds like excesses". I would like to try the Rubicon Trail next year and I like driving in the Mojave CA. It will get me to the secluded hunting camps that I like and that was my initial goal.
I just want to make sure Ive got all of my ducks in a row.
EDIT: It is my daily driver also so I want to keep it functional for long road trip comfort (as much as can be expected anyway).
post #14 of 28 Old 06-21-2010, 09:34 PM
justanotherjpr
Makes sense. Are you running a stock tie rod? Do you have a steering box skid? Those are two commonly overlooked items. I carry a complete spare steering system. A stock setup is cheap and I have needed the parts on the trail before.
post #15 of 28 Old 06-21-2010, 11:19 PM
Imped
Imped's Avatar
Stop worrying about "max flex" and get a Currie Antirock. People around here tend to put max flex on a pedestal when other things should come first.
OlllllllO
IndyORV
Imped is offline
compression test results?? meha11 TJ Wrangler Technical Forum 5 06-03-2010 12:17 PM
Compression Test Results bleached YJ Wrangler Technical Forum 13 05-07-2009 02:19 PM
Smog test results 95 yj moonshinefuel YJ Wrangler Technical Forum 5 04-17-2009 05:47 PM
Compression test results thechrisgibson YJ Wrangler Technical Forum 16 12-31-2004 06:33 PM
Compression Test Results? ErikJordan YJ Wrangler Technical Forum 7 03-06-2003 03:28 PM
