LJ Engine won't go below 2K - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > LJ Engine won't go below 2K
Unread 10-06-2013, 06:14 PM   #1
2ndmardiv
Smooth Up In Ya
Brought the LJ in for some exhaust work and a tune up. Ended up replacing the cracked exhaust manifold. When I drove it to work the next day, the engine wouldn't go below 2K RPM's. When I release the brakes after a stop, the Jeep accelerates up to about 20 mph without my foot on the gas.
God, Family, Country, Honor...the rest aint worth spit.
2ndmardiv is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 06:18 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Vacuum line left off the intake manifold?
Intake manifold not seated properly on the engine head causing a vacuum leak?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 06:34 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The mechanic didn't get the intake manifold properly seated to the intake manifold which is a common issue for an inattentive or rushed mechanic. That he gave the Jeep back to you without bother to fix that problem he caused is inexcusable.
It could also be a vacuum line left off the intake manifold like Knuckelhead mentioned but my bet is the intake manifold wasn't properly seated by the mechanic. There are two small positioning studs on the head that the mechanic has to get the intake manifold properly positioned over. I wouldn't use that mechanic again, that's for sure.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 07:33 PM   #4
2ndmardiv
Smooth Up In Ya
Jerry and Knucklehead, thanks a lot for the information.
