LJ DIY "insta-trunk" PDF plans - Page 2 - JeepForum.com
post #16 of 31 Old 10-30-2011, 10:48 AM
mark02tj
Can someone else grab the plans and post them so that you don't need to go into Google Docs to see them?
mark02tj is offline
post #17 of 31 Old 11-12-2011, 11:04 AM Thread Starter
UnlimitedJDB
Ok, finally got around to adding photos. There are a few dimensions that I would tweak if I did it again, but it worked out really well.
UnlimitedJDB is offline
post #18 of 31 Old 11-12-2011, 01:28 PM
jon1371usmc
Looks great.
jon1371usmc is offline
post #19 of 31 Old 11-12-2011, 05:09 PM
rottenrobert
Looks sweet. Makes me want to make one. Got to wait till spring tho. I put the Jeep in storage for winter.
rottenrobert is offline
post #20 of 31 Old 11-13-2011, 02:21 AM
Kiwi Jeeper
You have just given me a great idea for a weekend project for my TJ.
'12 JK Rubicon V6 3.6L
'15 KL Trailhawk V6 3.2L
Kiwi Jeeper is offline
post #21 of 31 Old 11-13-2011, 08:38 AM
kgginslc
Looks great - how did you make the 90 bend in the aluminum plate?
kgginslc is offline
post #22 of 31 Old 11-13-2011, 11:30 PM Thread Starter
UnlimitedJDB
My father in law owns a machine shop
I'm sure that you could have any shop shear and bend a sheet for you for next to nothing. Another option would be to get an 2" angle and rivet the top and back to it.
Also I should mention that the location for the door hatch is incorrect. Should be 9" from the end, not the cut corner. I will try to update the PDFs asap.
post #23 of 31 Old 11-14-2011, 10:20 PM
newman_buddy
Great idea and great looking.
Yellow Jeep Club - #34
LJ Owners - #34
2006 6,742 Unlimited Rubicon's made
newman_buddy is offline
post #24 of 31 Old 12-29-2012, 09:38 AM
bigsky006667
I am planning on using these plans for my LJ. How is it holding up and would you make any hanges to the design?
bigsky006667 is offline
post #25 of 31 Old 03-26-2013, 09:38 AM
my996duc1
old thread.... but exactly what I am looking for.
I can't see the drawings/specs on the storage box.
Any other way to get ahold of this info ??
_
2005 LJ Rubicon Sahara #0090 / MetalCloak'd / Currie 4" Lift with AntiRock / 35x12.50 GoodYear Kevlars / UCF skids
My build : http://www.wranglerforum.com/f5/rubicon-sahara-build-chronicles-328649.html
my996duc1 is offline
post #26 of 31 Old 03-26-2013, 12:01 PM
Blu-Ru
_
The plans are in the link at the end of the first post. I clicked it and it opened for me.
Blu-Ru is offline
post #27 of 31 Old 03-26-2013, 01:11 PM
JStrider
really like this design... seems like instead of having the threaded links on the outside you could angle the vertical piece so the child restraint anchors were inside the box, and then have those threaded links on the inside where they were more secure.
ON-ON
JStrider is offline
post #28 of 31 Old 09-24-2013, 02:09 PM
Sundown1
UnlimitedJDB:
Looks great I want to make one similar for my TJ, I have been looking at the diamond plate, what gauge or thickness is the one you made??
Thanks
Ron
Sundown1 is offline
post #29 of 31 Old 09-25-2013, 04:54 PM Thread Starter
UnlimitedJDB
Originally Posted by Sundown1 View Post
UnlimitedJDB:
Thanks
Ron
PM's you back, but I will answer here in case the same question comes up.
I believe it was 1/4" thick. I think it works well, but would consider adding an angle along the back if you plan on loading anything really heavy back there, but I mounted my jack across the back and that takes all the flex out of the middle. It's been about 2 years and it still looks brand new, and I wouldn't change a thing.
2005 LJ:
3" Zone coil lift-33x10.50 toyo MTs-Custom painted ravines-Custom home brew bumper
Smittybilt XRC comp winch-Smittybilt SRC roof rack-Custom home brew insta-trunk
post #30 of 31 Old 09-02-2015, 03:06 PM
Rugged_Ridge
Vendor
Rugged_Ridge's Avatar
2009 JK Wrangler
As you can see from my user name I work for Rugged Ridge.
Would you mind sending the PDF to me for use on my personal LJ. I do not see the link or any way ot access the google.doc that was being talked bout.
Nothing will be used for anything other than my own use, nothing though the company or anything.
rmichael@omix-ada.com
We Make Jeeps Rock |
Rugged_Ridge is offline
box , diy , lj , trunk cover
Insta-trunk that covers the whole LJ trunk? viperbluelx TJ Wrangler Technical Forum 12 12-19-2012 09:40 AM
Was there ever a LJ insta-trunk? keithert TJ Wrangler Technical Forum 1 03-15-2011 10:19 AM
need an insta trunk archer75 TJ Wrangler Technical Forum 3 10-02-2007 08:17 AM
insta trunk xl 90XJ02TJ TJ Wrangler Technical Forum 0 02-16-2003 01:53 PM
Insta-trunk, Anybody got one? battlestar YJ Wrangler Technical Forum 3 08-09-2002 05:00 PM
