-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   LJ DIY "insta-trunk" PDF plans (http://www.jeepforum.com/forum/f9/lj-diy-insta-trunk-pdf-plans-1282569/)
UnlimitedJDB 10-28-2011 09:37 AM
I have been looking high and low for some and insta-trunk for my LJ and came up empty handed, then I took a look at the boards and it turns out I'm not the only one who is after one. I went though the trouble of designing one, so I figured I would share the plans if there is anyone else out there who wants to make one. I'm using checker plate aluminum, but you could use plywood or steel and it would work just as well. I wanted a continuous bed look, so it extends the full length of tub, as opposed to stopping at the wheel wells like other designs I have seen. For security I am going to used a threaded chain link with lock tight secured to the baby seat floor attachment points, which will allow me to remove it if I have to, but will be enough to stop random thieves...unless they have a crescent wrench and are smart enough to flip the seat down.I will also rivit an alum. angle to the rear door so that when it is closed the trunk can't be lifted. This will allow the trunk to be secure, but it wont have to be screwed into the tub at all. I will post photos when it is done. This can be modified to suit a TJ as well. Let me know if you have any questions.
J
http://i1218.photobucket.com/albums/...J/P1040669.jpg
http://i1218.photobucket.com/albums/...J/P1040671.jpg
http://i1218.photobucket.com/albums/...J/P1040668.jpg
http://i1218.photobucket.com/albums/...J/P1040673.jpg
http://i1218.photobucket.com/albums/...J/P1040675.jpg
And with the off cuts I made some bumper caps!
http://i1218.photobucket.com/albums/...J/P1040677.jpg
https://docs.google.com/open?id=0B9i...EyZDY0OGI1ZWQ5
UnlimitedJDB 10-28-2011 09:38 AM
crap, I can't seem to post PDFs...any one want to help me out with this?
chitownEMT 10-28-2011 09:39 AM
Post a link to an external site?
UnlimitedJDB 10-28-2011 09:48 AM
So I have to post them somewhere else first?
JonnieBlaze 10-28-2011 10:03 AM
would google docs work?
Interested in seeing these plans....I've been wanting to build one but been busy working on some tube fenders.
UnlimitedJDB 10-28-2011 10:04 AM
Never mind...I'm a new member and I have to post 30 photos before you will be able to see them...that might take a while. If you want to plans just PM me and I will email them to you.
KillerSloth 10-28-2011 10:05 AM
Try Google docs, or you may be able to convert it to a .tiff file to post on any image hosting site. If you don't have the ability to do that, you can send it to me and I can do it for you.
UnlimitedJDB 10-28-2011 10:13 AM
I think I got it figured out...Sorry for the rapid posts!
UnlimitedJDB 10-28-2011 10:18 AM
Ok, that seems to work. Can someone confirm for me? I have 1:1s of all the cut outs as well.
UnlimitedJDB 10-28-2011 10:22 AM
I should also mention that you have to remove your windows/hard top to get this in, and it might prove to me a major pain in the butt, but I was able to work in a cardboard template with only a few curses. :D
sludge 10-28-2011 11:08 AM
That works, I can access it.
wytewolf00 10-28-2011 11:22 AM
Looks pretty good. There's no vertical height on the rear (I think?) section, though. It shows how tall the bottom part (wheel well) is, but nothing for the total height.
I was thinking about doing something similar to this, with a front panel that locks as well. My tailgate lock doesn't always like to cooperate with me, so I would need a way to secure the box and it's contents.
UnlimitedJDB 10-28-2011 12:40 PM
The overall height is 12 1/2". I will amend the drawing when I get a chance.
I never labeled the drawings because I didn't really plan on showing anyone, but the top is the plan view (looking from the top) and the one on the bottom is the elevation (looking from the back of the jeep. The overall height is 12 1/2"
You could add a piano hinge and another 12x32" plate with a hasp to the floor if you dont want to rely on the gate for security, the only issue I see with this is the gate latch pin, but you can just notch the plate.
UnlimitedJDB 10-29-2011 09:49 AM
I updated the drawings and put the link on the first post. I am going to build it today and will post pictures
UTWeezul 10-29-2011 06:05 PM
I've been planning something like this but will go all the way over the rear cargo area (I don't run a rear seat). I plan to bolt the top to the wheel wells and have some tie downs on top of it.
The time now is 08:22 AM.
