LJ Clayton Pro series long arm kit....... - JeepForum.com
post #1 of 65 Old 09-28-2012, 03:07 PM Thread Starter
GMBNT42
Looking at picking up this kit: http://claytonoffroad.com/product_in...roducts_id/356
I like the idea of a 3 link up front, with a triangulated 4 link in the rear that eliminates the rear trackbar. Uses all 2.5" JJ(which I would not use in favor of the Metal Cloak Duraflex joints which will swap right in)housings allowing me to use duroflex joints instead.
I know alot of people here don't like the long arm kits with the TJ's, but with the LJ platform, seems like this might be a favorable setup in a number of ways for my needs and a better performing setup vs. the available short arm setups.
I know the big issue with TJ's is getting hung up on the arms on the breakover, but on the LJ's it does not seem like that would be as much of an issue. Even with a 5.5" LA setup, the Clayton control arms themselves seem like that are still tucked closer to the frame than the stock control arms and specifically those large honking frame side mounts they go into both front and rear.
Any thoughs and experiences from LJ owners with this kit or a similiar LA setup?
GMBNT42 is offline
post #2 of 65 Old 09-28-2012, 04:21 PM
Imped
Imped's Avatar
I'm confused as to why you think the under-frame footprint is improved with an LJ over a TJ.
OlllllllO
IndyORV
Imped is offline
post #3 of 65 Old 09-28-2012, 04:43 PM Thread Starter
GMBNT42
Under frame footprint? Im talking about overall stability of the LJ vs. the TJ. Long arms seem to significantly hurt breakover angle on the TJ, but on the LJ seems like really a non issue with no real negative effects.
GMBNT42 is offline
post #4 of 65 Old 09-28-2012, 04:57 PM
Imped
Imped's Avatar
Breakover = under frame footprint. If anything, the problem is worsened with an LJ due to the longer wheelbase and larger distance between the skid plate and rear axle.
Where does stability even enter that discussion?
This should help explain footprint:
Large footprint--lots to get caught up on
Small footprint--minimal junk to get caught up on
OlllllllO
IndyORV
Imped is offline
post #5 of 65 Old 09-28-2012, 05:09 PM Thread Starter
GMBNT42
That is not a Clayton LA kit though.......
GMBNT42 is offline
post #6 of 65 Old 09-28-2012, 08:34 PM
dreed
Are you lifting your Jeep now? This would be a bad idea if your going to keep it low.
dreed is offline
post #7 of 65 Old 09-28-2012, 08:43 PM
Jankoid
The Clayton kit uses the same arms regardless of it being a TJ or LJ. On an LJ the mounts are just further back on the frame. They don't attach to the skid like RE. Other than that, I'm staying out of this debate.
Jankoid is offline
post #8 of 65 Old 09-28-2012, 08:51 PM
williambmac
I have a Clayton kit in my LJ and I love it.
Not to start a pissing match with the LA vs. SA,
I have had both and the LA rides much nicer on the street for a dd.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #9 of 65 Old 09-28-2012, 09:34 PM Thread Starter
GMBNT42
From what I understand the LJ long arm kits are slightly different in the rear vs. the TJ other than just where they mount to the frame. Or at least that is what CLayton mfg. told me.
GMBNT42 is offline
post #10 of 65 Old 09-28-2012, 09:35 PM Thread Starter
GMBNT42
Yep, I had a chance to ride in an LJ today with the standard 4" long arm lift kit, and I was actually really impressed with the on road ride quality. REALLY IMPRESSED.
GMBNT42 is offline
post #11 of 65 Old 09-28-2012, 09:43 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
you do realize that the TJ and LJ are identical in every way, except for 10" of extra frame rail, right?
My builds:
and
or follow us on
spyder6 is offline
post #12 of 65 Old 09-28-2012, 11:52 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea they are slightly different due to the WB. I am running a Clayton LA with 5" stretch.....I love it. Yea I have run a ground (rock) on one of the lower control arm mounts....once so far. I still hang up on my diffs regularly...just like everybody else.
It's a quality kit.....I know everybody thinks it's a bolt on.....well the control arms are after you cut the OEM brackets off & weld on the Clayton control arm brackets, truss and if you got the high clearance brackets for the axle & whatever else you plan on doing to it.
It's really no different than if you built your own brackets.....your still doing the same work. Only difference is Clayton gives you a print to follow & parts to install.
wushaw is offline
post #13 of 65 Old 09-29-2012, 01:42 AM
_KONG_
Just repeat the opposite of everything you just said and your statements will make sense. Did you just skip over the part that says "Recommended lift height range 5.5" to 8" of lift."?
_KONG_ is offline
post #14 of 65 Old 09-29-2012, 06:52 AM
williambmac
The only difference is the rear frame brackets.
post #15 of 65 Old 09-29-2012, 07:38 AM Thread Starter
GMBNT42
I could have sworn that when talking to Clayton they said that the rear control arms are slightly different in length too.........not 100% sure though.....Ill double check on Monday.
GMBNT42 is offline
Clayton Long Arm Kit IH8ROADZ TJ Wrangler Technical Forum 6 04-05-2011 06:21 AM
Clayton Long Arm upgrade ???? 00CHRIS TJ Wrangler Technical Forum 1 10-18-2009 08:28 PM
clayton long arm spyder6 TJ Wrangler Technical Forum 57 07-29-2009 12:58 AM
clayton long arm vs Rubicon Express long arm Squeeky TJ Wrangler Technical Forum 5 01-09-2008 10:16 PM
Clayton Long Arm kit 92blazn TJ Wrangler Technical Forum 33 01-11-2006 06:28 PM
